by joeoden » Mon May 09, 2011 2:49
Did you update first before trying to install
- Code: Select all
# equo update
Did you also try equo search
- Code: Select all
sabdaily-dt-joe josef # equo search firefox
>> @@ Searching...
>> @@ Package: www-client/firefox-4.0.1 branch: 5, [sabayonlinux.org]
>> Available: version: 4.0.1 ~ tag: NoTag ~ revision: 0
>> Installed: version: 4.0.1 ~ tag: NoTag ~ revision: 0
>> Slot: 0
>> Homepage: http://www.mozilla.com/firefox
>> Description: Firefox Web Browser
>> License: GPL-2 LGPL-2.1 MPL-1.1
>> @@ Package: www-client/firefox-bin-3.6.16 branch: 5, [sabayonlinux.org]
>> Available: version: 3.6.16 ~ tag: NoTag ~ revision: 0
>> Installed: version: Not installed ~ tag: N/A ~ revision: N/A
>> Slot: 0
>> Keywords: firefox
>> Found: 2 entries
Have you tried using the GUI package sulfur, it is very easy to use
Desktop ASUS M2N-MX SE Plus, AMD 64 X2 Dual Core 5200, 4 Gb RAM, GeForce 9500 1GB
Notebook HP CQ61-311AX, AMD CPU M320, 4 Gb RAM, Radeon HD 4300 512 MB
Wireless AR9285, Audio ATI SBx00 (IDT 92hd75B2x5)
Some mistakes are too much fun to only make once!
