I can't get DVDStyler to run. It nags about libraries.
- Code: Select all
dvdstyler: Symbol `_ZTV9wxSVGCtrl' has different size in shared object, consider re-linking
mjpegtools mplex-2 version 1.9.0 (2.2.7)
Usage: mplex [params] -o <output filename pattern> <input file>...
%d in the output file name is by segment count
where possible params are:
--verbose|-v num
Level of verbosity. 0 = quiet, 1 = normal 2 = verbose/debug
--format|-f fmt
Set defaults for particular MPEG profiles
[0 = Generic MPEG1, 1 = VCD, 2 = user-rate VCD, 3 = Generic MPEG2,
4 = SVCD, 5 = user-rate SVCD
6 = VCD Stills, 7 = SVCD Stills, 8 = DVD with NAV sectors, 9 = DVD]
--mux-bitrate|-r num
Specify data rate of output stream in kbit/sec
(default 0=Compute from source streams)
--video-buffer|-b num [, num...]
Specifies decoder buffers size in kB. [ 20...2000]
--lpcm-params | -L samppersec:chan:bits [, samppersec:chan:bits]
--mux-limit|-l num
Multiplex only num seconds of material (default 0=multiplex all)
--sync-offset|-O num ms|s|mpt
Specify offset of timestamps (video-audio) in mSec
--sector-size|-s num
Specify sector size in bytes for generic formats [256..16384]
--vbr|-V
Force variable bit-rate video multiplexing
--cbr|-C
Force constant bit-rate video multiplexing
--run-in|-R num
Force a 'run-in' of exactly num frame intervals
--packets-per-pack|-p num
Number of packets per pack generic formats [1..100]
--system-headers|-h
Create System header in every pack in generic formats
--max-segment-size|-S size
Maximum size of output file(s) in Mbyte (default: 0) (no limit)
--ignore-seqend-markers|-M
Don't switch to a new output file if a sequence end marker
is encountered ithe input video.
--vdr-index|-i <vdr-index-filename>
Generate a VDR index file with the output stream
--workaround|-W workaround [, workaround ]
--help|-?
Print this lot out!
*** glibc detected *** dvdstyler: free(): invalid pointer: 0x09426a70 ***
======= Backtrace: =========
/lib/libc.so.6(+0x6b821)[0xb610d821]
/lib/libc.so.6(+0x6d088)[0xb610f088]
/lib/libc.so.6(cfree+0x6d)[0xb611216d]
/usr/lib/libwx_baseu-2.8.so.0(_Z6wxOpenPKwij+0x5a)[0xb7264aca]
/usr/lib/libwx_baseu-2.8.so.0(_ZN6wxFile4OpenEPKwNS_8OpenModeEi+0x53)[0xb725c7d3]
/usr/lib/libwx_baseu-2.8.so.0(_ZN6wxFileC1EPKwNS_8OpenModeE+0x3d)[0xb725c8bd]
/usr/lib/libwx_baseu-2.8.so.0(_ZN17wxFileInputStreamC1ERK8wxString+0x5d)[0xb72b6aed]
/usr/lib/libwxsvg.so.0(_ZN16wxSvgXmlDocument4LoadERK8wxStringS2_+0x2c)[0xb71c152c]
dvdstyler[0x809ee9a]
dvdstyler[0x80a0d47]
dvdstyler[0x80f0a3c]
dvdstyler[0x813ee86]
dvdstyler[0x81478b8]
/usr/lib/libwx_baseu-2.8.so.0(_Z7wxEntryRiPPw+0x70)[0xb7278950]
/usr/lib/libwx_baseu-2.8.so.0(_Z7wxEntryRiPPc+0x37)[0xb7278b57]
dvdstyler[0x814637b]
/lib/libc.so.6(__libc_start_main+0xe6)[0xb60b8bb6]
dvdstyler[0x80672b1]
======= Memory map: ========
08048000-081b1000 r-xp 00000000 fb:00 791680 /usr/bin/dvdstyler
081b1000-081b2000 r--p 00168000 fb:00 791680 /usr/bin/dvdstyler
081b2000-081b4000 rw-p 00169000 fb:00 791680 /usr/bin/dvdstyler
081b4000-081bd000 rw-p 00000000 00:00 0
09021000-09e08000 rw-p 00000000 00:00 0 [heap]
b2800000-b2821000 rw-p 00000000 00:00 0
b2821000-b2900000 ---p 00000000 00:00 0
b2976000-b29d6000 rw-s 00000000 00:04 2392083 /SYSV00000000 (deleted)
b29d6000-b2a21000 rw-p 00000000 00:00 0
b2a21000-b2ab7000 r--p 00000000 fb:00 1580434 /usr/share/fonts/misc/18x18ja.pcf.gz
b2ab7000-b2ab9000 r-xp 00000000 fb:00 1334357 /usr/lib/pango/1.6.0/modules/pango-hangul-fc.so
b2ab9000-b2aba000 r--p 00001000 fb:00 1334357 /usr/lib/pango/1.6.0/modules/pango-hangul-fc.so
b2aba000-b2abb000 rw-p 00002000 fb:00 1334357 /usr/lib/pango/1.6.0/modules/pango-hangul-fc.so
b2abb000-b3a50000 r--p 00000000 fb:00 525076 /usr/share/fonts/unifont/unifont.ttf
b3a50000-b3ef4000 r--p 00000000 fb:00 524967 /usr/share/icons/hicolor/icon-theme.cache
b3ef4000-b4398000 r--p 00000000 fb:00 524967 /usr/share/icons/hicolor/icon-theme.cache
b4398000-b443f000 r--p 00000000 fb:00 920501 /usr/share/fonts/dejavu/DejaVuSans.ttf
b443f000-b4441000 r-xp 00000000 fb:00 1334355 /usr/lib/pango/1.6.0/modules/pango-basic-fc.so
b4441000-b4442000 r--p 00001000 fb:00 1334355 /usr/lib/pango/1.6.0/modules/pango-basic-fc.so
b4442000-b4443000 rw-p 00002000 fb:00 1334355 /usr/lib/pango/1.6.0/modules/pango-basic-fc.so
b4443000-b4449000 r--s 00000000 fb:00 3153298 /var/cache/fontconfig/87f5e051180a7a75f16eb6fe7dbd3749-le32d4.cache-3
b4449000-b444f000 r--s 00000000 fb:00 3153303 /var/cache/fontconfig/acc285bc1956c3c4bc7afb41d537a85a-le32d4.cache-3
b444f000-b445c000 r--s 00000000 fb:00 3151078 /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-le32d4.cache-3
b445c000-b4463000 r--s 00000000 fb:00 3151364 /var/cache/fontconfig/12b26b760a24f8b4feb03ad48a333a72-le32d4.cache-3
b4463000-b446d000 r-xp 00000000 fb:00 1581292 /lib/libnss_files-2.11.2.so
b446d000-b446e000 r--p 00009000 fb:00 1581292 /lib/libnss_files-2.11.2.so
b446e000-b446f000 rw-p 0000a000 fb:00 1581292 /lib/libnss_files-2.11.2.so
b446f000-b4478000 r-xp 00000000 fb:00 1581326 /lib/libnss_nis-2.11.2.so
b4478000-b4479000 r--p 00008000 fb:00 1581326 /lib/libnss_nis-2.11.2.so
b4479000-b447a000 rw-p 00009000 fb:00 1581326 /lib/libnss_nis-2.11.2.so
b447a000-b4480000 r-xp 00000000 fb:00 1581288 /lib/libnss_compat-2.11.2.so
b4480000-b4481000 r--p 00006000 fb:00 1581288 /lib/libnss_compat-2.11.2.so
b4481000-b4482000 rw-p 00007000 fb:00 1581288 /lib/libnss_compat-2.11.2.so
b4482000-b4483000 r--s 00000000 fb:00 3153302 /var/cache/fontconfig/f55bbeb01d684dc5b5f7b2c347cc42d9-le32d4.cache-3
b4483000-b4485000 r--s 00000000 fb:00 3153301 /var/cache/fontconfig/76fa4b957c916922374347f144bde9da-le32d4.cache-3
b4485000-b4488000 r--s 00000000 fb:00 3151386 /var/cache/fontconfig/a595ca43be94766bbfe429f07fba82d0-le32d4.cache-3
b4488000-b4489000 r--s 00000000 fb:00 3153236 /var/cache/fontconfig/f6b893a7224233d96cb72fd88691c0b4-le32d4.cache-3
b4489000-b449c000 r--s 00000000 fb:00 3153297 /var/cache/fontconfig/4b5cf4386f1cde02a336ba961b4ac82d-le32d4.cache-3
b449c000-b44a5000 r-xp 00000000 fb:00 3150775 /usr/lib/gtk-2.0/2.10.0/engines/libxfce.so
b44a5000-b44a6000 r--p 00008000 fb:00 3150775 /usr/lib/gtk-2.0/2.10.0/engines/libxfce.so
b44a6000-b44a7000 rw-p 00009000 fb:00 3150775 /usr/lib/gtk-2.0/2.10.0/engines/libxfce.so
b44a7000-b46a7000 r--p 00000000 fb:00 3015629 /usr/lib/locale/locale-archive
b46a7000-b46ae000 rw-p 00000000 00:00 0
b46ae000-b46ee000 r-xp 00000000 fb:00 262245 /lib/libncurses.so.5.7
b46ee000-b46f0000 r--p 0003f000 fb:00 262245 /lib/libncurses.so.5.7
b46f0000-b46f1000 rw-p 00041000 fb:00 262245 /lib/libncurses.so.5.7
b46f1000-b46f6000 r-xp 00000000 fb:00 1334578 /usr/lib/libogg.so.0.7.1
b46f6000-b46f7000 r--p 00004000 fb:00 1334578 /usr/lib/libogg.so.0.7.1
b46f7000-b46f8000 rw-p 00005000 fb:00 1334578 /usr/lib/libogg.so.0.7.1
b46f8000-b46f9000 rw-p 00000000 00:00 0
b46f9000-b4702000 r-xp 00000000 fb:00 1315931 /usr/lib/libdrm.so.2.4.0
b4702000-b4703000 r--p 00008000 fb:00 1315931 /usr/lib/libdrm.so.2.4.0
b4703000-b4704000 rw-p 00009000 fb:00 1315931 /usr/lib/libdrm.so.2.4.0
b4704000-b4715000 r-xp 00000000 fb:00 1334611 /usr/lib/libxcb-glx.so.0.0.0
b4715000-b4716000 r--p 00011000 fb:00 1334611 /usr/lib/libxcb-glx.so.0.0.0
b4716000-b4717000 rw-p 00012000 fb:00 1334611 /usr/lib/libxcb-glx.so.0.0.0
b4717000-b4718000 r-xp 00000000 fb:00 799458 /usr/lib/libX11-xcb.so.1.0.0
b4718000-b4719000 r--p 00000000 fb:00 799458 /usr/lib/libX11-xcb.so.1.0.0
b4719000-b471a000 rw-p 00001000 fb:00 799458 /usr/lib/libX11-xcb.so.1.0.0
b471a000-b471b000 rw-p 00000000 00:00 0
b471b000-b471d000 r-xp 00000000 fb:00 3026427 /usr/lib/libts-1.0.so.0.1.1
b471d000-b471e000 r--p 00001000 fb:00 3026427 /usr/lib/libts-1.0.so.0.1.1
b471e000-b471f000 rw-p 00002000 fb:00 3026427 /usr/lib/libts-1.0.so.0.1.1
b471f000-b4736000 r-xp 00000000 fb:00 3024933 /usr/lib/libaa.so.1.0.4
b4736000-b4737000 r--p 00017000 fb:00 3024933 /usr/lib/libaa.so.1.0.4
b4737000-b4738000 rw-p 00018000 fb:00 3024933 /usr/lib/libaa.so.1.0.4
b4738000-b473b000 rw-p 00000000 00:00 0
b473b000-b4747000 r-xp 00000000 fb:00 1456390 /usr/lib/libva-0.31.1.1.so.1.0.3
b4747000-b4748000 r--p 0000c000 fb:00 1456390 /usr/lib/libva-0.31.1.1.so.1.0.3
b4748000-b4749000 rw-p 0000d000 fb:00 1456390 /usr/lib/libva-0.31.1.1.so.1.0.3
b4749000-b4757000 r-xp 00000000 fb:00 792200 /usr/lib/libfaac.so.0.0.0
b4757000-b4758000 r--p 0000d000 fb:00 792200 /usr/lib/libfaac.so.0.0.0
b4758000-b475b000 rw-p 0000e000 fb:00 792200 /usr/lib/libfaac.so.0.0.0
b475b000-b4765000 r-xp 00000000 fb:00 933029 /usr/lib/libgsm.so.1.0.12
b4765000-b4766000 r--p 00009000 fb:00 933029 /usr/lib/libgsm.so.1.0.12
b4766000-b4767000 rw-p 0000a000 fb:00 933029 /usr/lib/libgsm.so.1.0.12
b4767000-b4768000 rw-p 00000000 00:00 0
b4768000-b47a9000 r-xp 00000000 fb:00 808516 /usr/lib/libmp3lame.so.0.0.0
b47a9000-b47aa000 r--p 00041000 fb:00 808516 /usr/lib/libmp3lame.so.0.0.0
b47aa000-b47ac000 rw-p 00042000 fb:00 808516 /usr/lib/libmp3lame.so.0.0.0
b47ac000-b47df000 rw-p 00000000 00:00 0
b47df000-b480c000 r-xp 00000000 fb:00 1192654 /usr/lib/libopencore-amrnb.so.0.0.2
b480c000-b480d000 r--p 0002c000 fb:00 1192654 /usr/lib/libopencore-amrnb.so.0.0.2
b480d000-b480e000 rw-p 0002d000 fb:00 1192654 /usr/lib/libopencore-amrnb.so.0.0.2
b480e000-b4823000 r-xp 00000000 fb:00 1192670 /usr/lib/libopencore-amrwb.so.0.0.2
b4823000-b4824000 r--p 00014000 fb:00 1192670 /usr/lib/libopencore-amrwb.so.0.0.2
b4824000-b4825000 rw-p 00015000 fb:00 1192670 /usr/lib/libopencore-amrwb.so.0.0.2
b4825000-b4835000 r-xp 00000000 fb:00 3026359 /usr/lib/libspeex.so.1.5.0
b4835000-b4836000 r--p 00010000 fb:00 3026359 /usr/lib/libspeex.so.1.5.0
b4836000-b4837000 rw-p 00011000 fb:00 3026359 /usr/lib/libspeex.so.1.5.0
b4837000-b4845000 r-xp 00000000 fb:00 1197751 /usr/lib/libtheoradec.so.1.1.4
b4845000-b4846000 r--p 0000d000 fb:00 1197751 /usr/lib/libtheoradec.so.1.1.4
b4846000-b4847000 rw-p 0000e000 fb:00 1197751 /usr/lib/libtheoradec.so.1.1.4
b4847000-b4872000 r-xp 00000000 fb:00 1205905 /usr/lib/libtheoraenc.so.1.1.2
b4872000-b4873000 r--p 0002b000 fb:00 1205905 /usr/lib/libtheoraenc.so.1.1.2
b4873000-b4874000 rw-p 0002c000 fb:00 1205905 /usr/lib/libtheoraenc.so.1.1.2Aborted
It's a pain. I reinstalled some of them but DVDStyler just moves to the next one to just nag about it. I had one moment when the application didn't nag about libraries but than segmentation faulted
Any help would be welcome...
Also avidemux is very unstable and lets me down quite a bit.
