Can't install arduino (missing avr-g++)
Postby rafaeltcc » Wed Nov 10, 2010 18:17
Using latest Sabayon 5.4 KDE 64bits
equo install arduino warns me:
Missing avr-g++; you need to crossdev -s4 avr
I do as told:
crossdev -s4 avr
Everything is emerged all right, no error or warning, but reruning "equo install arduino" brings me the same warning. It seems as if avr-g++ hasn't been built...
Thanks a lot for any help.. For now I have to use a virtual machine with ubuntu to use my arduino...
eix -I avr && eix -I gcc
[U] dev-embedded/avrdude
Available versions: (~)5.4 5.5 (~)5.8 {doc}
Installed versions: 5.5(15:33:13 20-10-2010)(-doc)
Homepage: http://savannah.nongnu.org/projects/avrdude
Description: AVR Downloader/UploaDEr
[U] sys-devel/gcc
Available versions:
(2.95) *2.95.3-r9 ~*2.95.3-r10!s
(3.1) *3.1.1-r2
(3.2) **3.2.2!s *3.2.3-r4
(3.3) (~)3.3.6-r1!s
(3.4) 3.4.6-r2!s
(4.0) ~*4.0.4!s
(4.1) 4.1.2!s
(4.2) (~)4.2.4-r1!s
(4.3) 4.3.2-r3!s (~)4.3.2-r4!s (~)4.3.3-r2!s 4.3.4!s (~)4.3.5!s
(4.4) (~)4.4.1!s (~)4.4.2!s 4.4.3-r2!s (~)4.4.3-r3!s (~)4.4.4!s (~)4.4.4-r1!s
(4.5) [M]**4.5.0!s [M]**4.5.1!s
{altivec bootstrap boundschecking build d doc fixed-point fortran gcj graphite gtk hardened ip28 ip32r10k java libffi lto mudflap multilib multislot n32 n64 nls nocxx nopie nossp nptl objc objc++ objc-gc openmp static test vanilla}
Installed versions: 4.4.2(4.4)!s(19:28:07 23-06-2010)(fortran gcj mudflap multilib nls nptl objc objc++ objc-gc openmp -altivec -bootstrap -build -doc -fixed-point -graphite -gtk -hardened -ip28 -ip32r10k -libffi -multislot -n32 -n64 -nocxx -test -vanilla)
Homepage: http://gcc.gnu.org/
Description: The GNU Compiler Collection.
[I] sys-devel/gcc-config
Available versions: 1.3.16 1.4.0-r4 1.4.1 **1.5
Installed versions: 1.4.1(19:28:07 23-06-2010)
Homepage: http://www.gentoo.org/
Description: Utility to change the gcc compiler being used
rafaeltcc
Re: Can't install arduino (missing avr-g++)
Postby rafaeltcc » Thu Nov 11, 2010 14:02
Hi, I had already tried that. I am in the same situation of the last one who posted in the bug report...
USE="-openmp" crossdev -s4 avr
is adequate to get a working avr-gcc, but not g++.
No warinng, no error, but avr-g++ isn't build or recognized...
rafaeltcc
Postby vsipola » Sun Jul 03, 2011 22:46
I believe I had the same problem.
For me it helped to first change manually the use flag for crossdev to -nocxx at /etc/portage/package.use, remove any repeated use flags from the line (there were several, apparently after multiple runs of the script) and then use
sudo USE="-nocxx" crossdev -s4 -t avr
as instructed by Mr. Chau at the other forum.
vsipola
Users browsing this forum: sqlpython and 2 guests
