Problem with libgnutls? Some GTK apps won't start. [Solved]
Postby Exospaciac » Thu Apr 24, 2008 8:37
After updating my nVidia drivers to the latest beta (173.08) and restarting X, I noticed a few GTK-based programs just wouldn't start.
I have no idea how updating my nVidia drivers correlates to libgnutls, but whatever.
Firefox, ccsm, and Portato start okay, and all my KDE apps start fine, but others refuse to start.
Two that I know for certain do not work are emerald-theme-manager and nvidia-settings.
Here's the output I get when trying to run these apps in a terminal:
mikey@l33tbox ~ $ emerald-theme-manager
(emerald-theme-manager:19573): Gtk-WARNING **: libgnutls.so.13: cannot open shared object file: No such file or directory
Segmentation fault
nvidia-settings
ERROR: The attribute 'ForceGenericCpu' specified on line 28 of configuration file '/home/mikey/.nvidia-settings-rc' cannot be assigned (it is a read-only
       attribute).
(nvidia-settings:19632): Gtk-WARNING **: libgnutls.so.13: cannot open shared object file: No such file or directory
Segmentation fault
I tried recompiling libgnutls, but that helped nothing.
So, what's going on?
Exospaciac
Re: Problem with libgnutls? Some GTK apps won't start.
Postby joost » Thu Apr 24, 2008 9:05
Maybe
revdep-rebuild
helps?
Postby wolfden » Thu Apr 24, 2008 12:01
revdep-rebuild for sure, that will effect a lot of packages too, so don't be surprised to see 50+ packages to be rebuilt
Postby Exospaciac » Thu Apr 24, 2008 17:22
Well I tried that but I found that my version of vorbis-tools wasn't in Portage any more.
So I tried to emerge the latest version and this happened:
mkdir .libs
i586-pc-linux-gnu-gcc -O2 -Wall -ffast-math -fsigned-char -Os -march=i586 -mno-tls-direct-seg-refs -mmmx -m32 -Wl,-O1 -Wl,--enable-new-dtags -Wl,--sort-common -s -o ogg123 audio.o buffer.o callbacks.o cfgfile_options.o cmdline_options.o file_transport.o format.o http_transport.o ogg123.o oggvorbis_format.o playlist.o status.o remote.o transport.o vorbis_comments.o flac_format.o easyflac.o speex_format.o  ../share/libutf8.a ../share/libgetopt.a /usr/lib/libvorbisfile.so /usr/lib/libvorbis.so -L/usr/lib /usr/lib/libao.so /usr/lib/libcurl.so -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lresolv -lnsl -ldl /usr/lib/libgnutls.so /usr/lib/libtasn1.so /usr/lib/libgcrypt.so /usr/lib/libgpg-error.so -lz -lpthread /usr/lib/libOggFLAC.so /usr/lib/libFLAC.so /usr/lib/libogg.so /usr/lib/libspeex.so -lm
/usr/lib/gcc/i586-pc-linux-gnu/4.1.2/../../../../i586-pc-linux-gnu/bin/ld: warning: libgnutls.so.13, needed by /usr/lib/libcurl.so, not found (try using -rpath or -rpath-link)
/usr/lib/libcurl.so: undefined reference to `gnutls_bye@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_certificate_verify_peers2@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_credentials_set@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_check_version@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_x509_crt_get_activation_time@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_strerror@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_x509_crt_get_version@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_certificate_free_credentials@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_certificate_set_verify_flags@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_x509_crt_init@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_certificate_get_peers@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_cipher_get@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_mac_get@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_x509_crt_get_dn@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_x509_crt_get_dn_by_oid@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_set_default_priority@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_session_set_data@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_init@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_compression_get@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_global_init@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_certificate_type_set_priority@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_handshake@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_transport_set_ptr@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_pk_algorithm_get_name@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_x509_crt_check_hostname@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_x509_crt_deinit@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_x509_crt_get_issuer_dn@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_certificate_allocate_credentials@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_deinit@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_mac_get_name@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_compression_get_name@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_certificate_set_x509_trust_file@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_record_recv@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_certificate_set_x509_key_file@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_record_send@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_cipher_get_name@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_global_deinit@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_x509_crt_import@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_x509_crt_get_expiration_time@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_session_get_data@GNUTLS_1_3'
/usr/lib/libcurl.so: undefined reference to `gnutls_x509_crt_get_pk_algorithm@GNUTLS_1_3'
collect2: ld returned 1 exit status
make[2]: *** [ogg123] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
Exospaciac
Postby wolfden » Fri Apr 25, 2008 2:58
You need to by synced via portage and layman first
Postby Exospaciac » Fri Apr 25, 2008 5:17
I did an emerge --sync && layman -S before I even did the revdep-rebuild.
I ran it again just now to be sure that wasn't the problem and it still fails at the same point.
Exospaciac
Postby xlnagla » Sat Apr 26, 2008 2:33
you're probably going to need to re-build curl, and maybe a few others.
As a side note....
something's not in portage anymore? That's a shame. check out my revdep-update script, but be warned you're probably going to have to work out a few things if you're still in 3.4f for most of the packages needing rebuild. May want to remove the ACCEPT_KEYWORDS="~x86" if your packages are old enough, they'll fail less often that way. the revdep-update script is in the sticky "revdep-rebuild woes?" in the portage and packaging forum.
~xlnagla
xlnagla
Postby Exospaciac » Sun May 04, 2008 21:37
Oops. I forgot about this thread :/
revdep-rebuild did the trick. Thanks a bunch!
Exospaciac
