I just recently ran across the answer for this here:
BASH invocation on Sab. . .In short, the xdm/kdm default login scheme used in Sabayon doesn't look at the .xinitrc or .xsession files in a user's directory. But if you edit and/or create a .xprofile file in the users home directory, and insert:
- Code: Select all
/usr/bin/xscreensaver &
...then you should have xscreensaver starting by default.
