Codeblocks crashes after it's been emerged correctly
Postby mhzuchini » Mon Mar 17, 2008 14:17
Hi, friends!
I've recently emerged "dev-util/codeblocks-1.0_pre20071215" on my SL notebook. Apparently, emerge has set up Code::Blocks correctly showing no errors. After that, I've tried to run Code::Blocks from command line but it crashed after a while. I was able to see the Code::Blocks' logo on screen for a second, but it was all I've got:
$ codeblocks
Initialize EditColourSet .....
Initialize EditColourSet: done.
Loading toolbar...
Debugger: loaded
Autosave: loaded
AStylePlugin: loaded
CodeCompletion: loaded
FilesExtensionHandler: loaded
ProjectsImporter: loaded
OpenFilesList: loaded
ToDoList: loaded
ScriptedWizard: loaded
Compiler: loaded
ClassWizard: loaded
Debugger plugin activated
Autosave plugin activated
Source code formatter (AStyle) plugin activated
Code completion plugin activated
Files extension handler plugin activated
Foreign projects importer plugin activated
Open files list plugin activated
To-Do List plugin activated
Project wizard added for 'Empty project'
Project wizard added for 'Console application'
Project wizard added for 'D application'
Project wizard added for 'FLTK project'
Project wizard added for 'GLFW project'
Project wizard added for 'GLUT project'
Project wizard added for 'GTK+ project'
Project wizard added for 'Irrlicht project'
Project wizard added for 'Lightfeather project'
Project wizard added for 'OpenGL project'
Project wizard added for 'Ogre project'
Project wizard added for 'Code::Blocks plugin'
Project wizard added for 'QT4 project'
Project wizard added for 'SDL project'
Project wizard added for 'Static library'
Project wizard added for 'Shared library'
Project wizard added for 'AVR Project'
Project wizard added for 'wxWidgets project'
Build-target wizard added for 'Console'
Build-target wizard added for 'wxWidgets'
File(s) wizard added for 'Empty file'
File(s) wizard added for 'C/C++ source'
File(s) wizard added for 'C/C++ header'
Scripted wizard plugin activated
Added compiler "GNU GCC Compiler"
Parsing stage done (0 total parsed files, 0 tokens in 0 minute(s), 0.0 seconds).
Updating class browser...
Class browser updated.
Added compiler "Intel C/C++ Compiler"
Added compiler "SDCC Compiler"
Added compiler "Tiny C Compiler"
Added compiler "GDC D Compiler"
Added compiler "Digital Mars D Compiler"
Added compiler "GNU ARM GCC Compiler"
Added compiler "GNU AVR GCC Compiler"
Added compiler "GNU GCC Compiler for PowerPC"
Added compiler "GNU GCC Compiler for TriCore"
*** glibc detected *** codeblocks: free(): invalid pointer: 0x000000000151cac0 ***
======= Backtrace: =========
/lib/libc.so.6[0x2acee4f58e0d]
/lib/libc.so.6(cfree+0x76)[0x2acee4f5ab06]
/usr/lib/libwx_gtk2u_core-2.8.so.0[0x2acee3e0a4f0]
/usr/lib/libwx_gtk2u_xrc-2.8.so.0(_ZN18wxButtonXmlHandler16DoCreateResourceEv+0x22e)[0x2acee35ec3b8]
/usr/lib/libwx_gtk2u_xrc-2.8.so.0(_ZN20wxXmlResourceHandler14CreateResourceEP9wxXmlNodeP8wxObjectS3_+0x343)[0x2acee360fed5]
/usr/lib/libwx_gtk2u_xrc-2.8.so.0(_ZN13wxXmlResource17CreateResFromNodeEP9wxXmlNodeP8wxObjectS3_P20wxXmlResourceHandler+0x374)[0x2acee3611438]
[...cut...]
I've been searching for some tips on such problem, but found none applicable to this problem (tips found include problems with wxWidgets, wxGTK, compiling problems and others. By the way, wxGTK is installed on my SL box: version 2.8.4.0).
Should I believe crash has something to do with "Added compiler "GNU GCC Compiler for TriCore"?
I would appreciate any help to show me any direction to search.
Thanks in advance!
Marcio.
______
Sony Vaio VGN-NW150AJ - 4GB RAM - Sabayon Linux amd64 8 GNOME
Linux 3.1.0-sabayon #1 SMP Sat Dec 31 00:06:24 UTC 2011 x86_64 Intel(R) Core(TM)2 Duo CPU T6500 @ 2.10GHz GenuineIntel GNU/Linux
mhzuchini
Crosspost: Codeblocks crashes after it's been emerged...
Postby mhzuchini » Thu Mar 20, 2008 1:02
Hi, friends!
I'm crossposting this issue here from "Software in general", maybe someone in this forum have had the same problem.
$ codeblocks
Loading toolbar...
Debugger: loaded
Autosave: loaded
ToDoList: loaded
Compiler: loaded
ClassWizard: loaded
[...cut...]
Thanks in advance!
Marcio.
______
mhzuchini
Re: Crosspost: Codeblocks crashes after it's been emerged...
Postby xlnagla » Thu Mar 20, 2008 1:41
No, if gcc was broken there'd be bigger signs than this, especially when you try to emerge stuff. this may have something to do with glibC, perhaps an incompatible version - looks like a function from one of your imported libraries is experiencing a segfault. Try recompiling glibc. You always can recompile gcc too if you'd like, but gcc upgrades should follow the gcc upgrade guide.
~xlnagla
xlnagla
Postby mhzuchini » Thu Apr 17, 2008 5:41
I've tried to compile codeblocks from source: I downloaded version 8.02, did "./configure ; make ; make install". As soon as I tried to run, I've got the exactly same error.
I found a link (http://wiki.codeblocks.org/index.php?ti ... _on_Gentoo) and realize that it's necessary to compile wxGTK with "gtk2" use flag. I also found that there is 2 wxGTK versions on my system:
# equery list wxGTK
[ Searching for package 'wxGTK' in all categories among: ]
 * installed packages
[I--] [M ] x11-libs/wxGTK-2.6.3.3 (2.6)
[I--] [M~] x11-libs/wxGTK-2.8.4.0 (2.8)
None of installed wxGTK apparently have "gtk2" flag enabled:
# equery uses wxGTK
[ Searching for packages matching wxGTK... ]
[ Colour Code : set unset ]
[ Legend : Left column  (U) - USE flags from make.conf              ]
[        : Right column (I) - USE flags packages was installed with ]
[ Found these USE variables for x11-libs/wxGTK-2.6.3.3 ]
 U I
 + + X        : Adds support for X11
 - - debug    : Enable extra debug codepaths, like asserts and extra output. If you want to get meaningful backtraces see http://www.gentoo.org/proj/en/qa/backtraces.xml
 - - doc      : Adds extra documentation (API, Javadoc, etc)
 + + gnome    : Adds GNOME support
 + + joystick : Add support for joysticks in all packages
 - - odbc     : Adds ODBC Support (Open DataBase Connectivity)
 + + opengl   : Adds support for OpenGL (3D graphics)
 + + sdl      : Adds support for Simple Direct Layer (media library)
 + + unicode  : Adds support for Unicode
[ Found these USE variables for x11-libs/wxGTK-2.8.4.0 ]
 U I
 + + gif      : Adds GIF image support
 - - stl      : <unknown>
Do you think I should try to update wxGTK to a newer (and just one) version with "gtk2" flag before trying to recompile glibc?
I am just a little bit afraid to mess up with glibc...
Marcio
______
mhzuchini
Postby xlnagla » Thu Apr 17, 2008 15:34
do not crosspost
sorry I missed that before. Let me know if you'd rather be in this forum instead of Software in General.
~xlnagla
xlnagla
Re: Codeblocks crashes after it's been emerged correctly
Postby mhzuchini » Sat Apr 19, 2008 6:03
Hi, xlnagla
I'm really sorry if I broke any rules.
I only did that because I was not sure what would be the best forum to ask for help on this question.
In fact, I didn't receive any comments on "Software in General", but if you think that's the better choice, I accept it.
Regards,
Marcio.
______
mhzuchini
Postby xlnagla » Fri Jun 06, 2008 3:50
okay, I'm sorry for the delay - if you haven't already what you were proposing is a fine idea. Also, glibc is generally safer to re-emerge these days, so don't worry too much about it.
~xlnagla
xlnagla
