when i ran the check it came up with this. i am looking for information on it. i didnt find (or understand) and answer from the link it gave.
~ $ java-check-environment
* === Java Environment Checker ===
* The purpose of this script is to check the sanity of your Java Environment.
* We have significantly changed and improved the way Java is handled in many
* respects.
* Please refer to our upgrade guide for details:
http://www.gentoo.org/proj/en/java/java-upgrade.xml * Checking fastjar ...
gcc-config error: /usr/bin/fastjar wrapper: Unable to determine executable.
CTARGET=i586-pc-linux-gnu
exec=fastjar
exec=fastjar
grep: test.txt: No such file or directory
* Your /usr/bin/fastjar was not able to create a jar file.
* See
https://bugs.gentoo.org/show_bug.cgi?id=135688 * for details. If you have had eselect-compiler installed
* just delete /usr/bin/fastjar. Otherwise report this to
http://bugs.gentoo.org. [ !! ]
[Edit]
i follwed the gentoo guide and upgraded java, but still getting the same error
[edit]
i copied fastjar and ran the check again, this time it had me install some other java config file, tried to emerge but would not work, followed the link to download from java and follwed the instuctions in terminal, installed the java config OK, checking again...
# java-check-environment
* respects.
http://www.gentoo.org/proj/en/java/java-upgrade.xml * Checking fastjar ... [ ok ]
* Checking vm_environment_files ... [ ok ]
* Checking user_settings ...
* Running as root. Don't need to check user settings. [ ok ]
* Checking generation_1_system_vm ... [ ok ]
* Checking virtual_provides ... [ ok ]
* Checking overlays_eclasses ... [ ok ]
* Checking package_env ... [ ok ]
* Java environment is sane. Congratulations!
now to run frost wire (i hope)
[edit]
now when i run frostwire from terminal, i get the same original error
