emerge glibc
emerge glibc
Postby chinchey » Wed Feb 13, 2008 18:39
Hi-
So, I updated python and ran python-updater, which wants to emerge glibc-2.7-r1. My question is, how long might I expect this compile to take? I left it running for a good 5 hours and it still isn't finished. Stuff goes by too fast for me to see what's really going on, but does anyone know how long this should take? Or maybe a reference, like "longer than gtk+ but shorter than kdelibs" or something like that? I've got a reasonably fast processor doing this, so I'm surprised something is taking this long. Thanks
chinchey
Re: emerge glibc
Postby chickpea » Wed Feb 13, 2008 18:52
it's one of the longest compiles in SL right up there with gcc. (I have a turion x86-64 x2 with 1G RAM for comparison).
chickpea
Re: emerge glibc
Postby gaffu » Wed Feb 13, 2008 19:08
Takes ~1 hour for me with an Athlon dual core @2200 MHz
gaffu
Re: emerge glibc
Postby chinchey » Wed Feb 13, 2008 22:03
See, it's been running for hours on an Athlon 64 X2 6400, at 3.2GHz. I really think it should be done by now...
chinchey
Re: emerge glibc
Postby DontPanic » Thu Feb 14, 2008 1:36
chinchey wrote:See, it's been running for hours on an Athlon 64 X2 6400, at 3.2GHz. I really think it should be done by now...
It's a long compile, but if you've got an Athlon 64 X2 6400, you're right. That sounds like it's taking too long to compile. Report back if you see something that made it take so long to compile.
Have you topped out on RAM?
Gigabyte GA-P35-DS3L - Intel(R) Core(TM)2 Duo CPU E6750@ 2.66GHz
nVidia GeForce 7600 GS
2 GB RAM
DontPanic
Re: emerge glibc
Postby chinchey » Thu Feb 14, 2008 2:09
Here's my /proc/meminfo while it's compiling (now at about 10 hours):
MemTotal: 2063888 kB
MemFree: 101792 kB
Buffers: 226044 kB
Cached: 1181556 kB
SwapCached: 0 kB
Active: 726244 kB
Inactive: 954468 kB
SwapTotal: 2096472 kB
SwapFree: 2096472 kB
Dirty: 3152 kB
Writeback: 0 kB
AnonPages: 272520 kB
Mapped: 63956 kB
Slab: 244924 kB
SReclaimable: 214804 kB
SUnreclaim: 30120 kB
PageTables: 5768 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
CommitLimit: 3128416 kB
Committed_AS: 409684 kB
VmallocTotal: 34359738367 kB
VmallocUsed: 43524 kB
VmallocChunk: 34359685115 kB
So, it looks like i've got available ram and no swap is being used at all. So I wouldn't think this is the issue. Anything else you might suggest I check?
chinchey
Re: emerge glibc
Postby chinchey » Thu Feb 14, 2008 7:55
Well, I left for about 5 hours and when I came back it was done... I don't know why it took so long still, though
chinchey
Re: emerge glibc
Postby gaffu » Thu Feb 14, 2008 9:15
See how many locales you are using in your system here: /etc/locale.gen The more you have, the longer it takes to compile.
Also post your CFLAGS (found in /etc/make.conf or typing emerge --info).
gaffu
Re: emerge glibc
Postby chinchey » Thu Feb 14, 2008 16:57
Everything in locale.gen is commented out:
#en_US ISO-8859-1
#en_US.UTF-8 UTF-8
#ja_JP.EUC-JP EUC-JP
#ja_JP.UTF-8 UTF-8
#ja_JP EUC-JP
#en_HK ISO-8859-1
#en_PH ISO-8859-1
#de_DE ISO-8859-1
#de_DE@euro ISO-8859-15
#es_MX ISO-8859-1
#fa_IR UTF-8
#fr_FR ISO-8859-1
#fr_FR@euro ISO-8859-15
#it_IT ISO-8859-1
And:
CFLAGS="-march=athlon64 -O2 -pipe"
chinchey
Users browsing this forum: No registered users and 5 guests
