LiVES - video editing
Postby oc12 » Thu Feb 07, 2008 16:49
Any one else use this or do video editing?
I installed it and having this problem.
LiVES 0.9.8.6
Copyright 2002-2007 Gabriel Finch (salsaman@xs4all.nl) and others.
LiVES comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details.
jackd 0.101.1
Copyright 2001-2005 Paul Davis and others.
jackd comes with ABSOLUTELY NO WARRANTY
JACK compiled with System V SHM support.
cannot create /var/run/jack/jack-1000 directory (Permission denied)
cannot create server sockets
cannot create engine
oc12
Re: LiVES - video editing
Postby WarraWarra » Fri Feb 08, 2008 9:19
You can either as root do it and it should work if not manually create the folder and try again then check /etc/fstab or /etc/mtab as likely some permission is set incorrectly for the root partition.
WarraWarra
