Here's what happens:
"#hald restart" returns one fo two things:
- Code: Select all
* Starting Hardware Abstraction Layer daemon ... [ !! ]
* ERROR: hald failed to start
OR
- Code: Select all
* start-stop-daemon: /usr/sbin/hald is already running [ !! ]
After this i tried to start/stop the daemon and here's the result:
- Code: Select all
localhost linux # /etc/init.d/hald stop
* WARNING: hald is already stopped
localhost linux # /etc/init.d/hald start
So i decided to use the status command and it seems like the /etc/init.d/hald is not running but the /usr/sbin/hald is. Now, i had never noticed or tried to find out if in a regular situatuion they are both running, but my guess is yes... So i decided to see what goin on:
- Code: Select all
# hald --daemon=no --verbose=yes
13:25:52.821 [I] hald.c:634: hal 0.5.10
13:25:52.822 [I] hald.c:699: Will not daemonize
13:25:52.822 [I] hald_dbus.c:5285: local server is listening at unix:abstract=/var/run/hald/dbus-9SAq0oBHw5,guid=22d1e465a4788393fd1da61a47a71260
13:25:52.822 [E] hald_dbus.c:5579: dbus_bus_get(): Failed to connect to socket /var/run/dbus/system_bus_socket: Connection refused
Now, i remeber updating dbus earlier on, is there something i'm supposed to do now to get things running again?
Thanks
I've been tweaking my pc for a while now and i found out that the problem is definately related to the dbus, since i have problems with the avahi daemon aswell:
- Code: Select all
Found user 'avahi' (UID 110) and group 'avahi' (GID 445).
Successfully dropped root privileges.
avahi-daemon 0.6.22 starting up.
dbus_bus_get_private(): Failed to connect to socket /var/run/dbus/system_bus_socket: Connection refused
WARNING: Failed to contact D-Bus daemon.
So i've been searching around in the sabayon forums and the gentoo forums/wiki but all i found was some people with similar problems but no solution
