SMplayer troubles
SMplayer troubles
Postby chickpea » Mon Feb 04, 2008 3:04
I just did a large world update, and even after running revdep-rebuild -X it still doesn't work. It runs fine, but it won't play any videos.
I can run mplayer just fine, but SMplayer doesn't want to play nice. I've rebuilt it again, but still no dice.
here is what konsole says when run from a terminal:
main: app name: smplayer
global_init
global_init: config file: '/home/bichinh0/.smplayer/smplayer.ini'
Preferences::load
Debug: Translator::loadCatalog: can't load qt_en_US from /usr/share/smplayer/translations
Debug: Translator::loadCatalog: can't load qt_en_US from /usr/share/qt4/translations
Debug: Translator::loadCatalog: can't load smplayer_en_US from /usr/share/smplayer/translations
This is SMPlayer v. 0.5.62 (svn r418) running on Linux
Debug: This is SMPlayer v. 0.5.62 (svn r418) running on Linux
Debug: Qt v. 4.3.3
Debug:  * application path: '/usr/bin'
Debug:  * data path: '/usr/share/smplayer'
Debug:  * translation path: '/usr/share/smplayer/translations'
Debug:  * doc path: '/usr/share/doc/smplayer-0.5.62'
Debug:  * themes path: '/usr/share/smplayer/themes'
Debug:  * shortcuts path: '/usr/share/smplayer/shortcuts'
Debug:  * smplayer home path: '/home/bichinh0/.smplayer'
Debug:  * ini path: '/home/bichinh0/.smplayer'
Debug: main: files_to_play: count: 0
Debug: Recents::load
Debug: Core::Core: file_settings: '/home/bichinh0/.smplayer/smplayer_files.ini'
Debug: MplayerProcess::init_rx
Debug: MplayerLayer::allowClearingBackground: 0
Debug: Preferences::monitor_aspect_double
Debug:  warning: monitor_aspect couldn't be parsed!
Debug:  monitor_aspect set to 0
Debug: Playlist::setModified: 0
Debug: Playlist::loadSettings
Debug: Playlist::addItem: '/home/bichinh0/Movies/Old.School.WS.UNRATED.DVDRip.XViD-DVL/dvl-os.avi'
Debug: name: 'dvl-os.avi'
Debug: Style name: 'plastique'
Debug: Style class name: 'QPlastiqueStyle'
Debug: BaseGui::initializeMenus
Debug: BaseGui::updateRecents
Debug: BaseGui::updateWidgets
Debug: PlaylistDock::hideEvent: isFloating: 0
Debug:  undocked
Debug: PlaylistDock::showEvent: isFloating: 1
Debug: PlaylistDock::hideEvent: isFloating: 1
Debug: BaseGuiPlus::loadConfig
Debug: DefaultGui::createStatusBar
Debug: DefaultGui::createActions
Debug: DefaultGui::createControlWidget
Debug: DefaultGui::createControlWidgetMini
Debug: DefaultGui::updateWidgets
Debug: DefaultGui::loadConfig
Debug: BaseGui::showEvent
Debug: BaseGui::loadActions
Debug: ActionsEditor::loadFromConfig
Debug: BaseGui::hideEvent
Debug: BaseGui::fileOpen
Debug: BaseGui::openFile: '/home/bichinh0/Movies/Old.School.WS.UNRATED.DVDRip.XViD-DVL/dvl-os.avi'
Debug: Core::openFile: '/home/bichinh0/Movies/Old.School.WS.UNRATED.DVDRip.XViD-DVL/dvl-os.avi'
Debug: Core::playNewFile: '/home/bichinh0/Movies/Old.School.WS.UNRATED.DVDRip.XViD-DVL/dvl-os.avi'
Debug: Core::saveMediaInfo
Debug: Core::checkHaveSettingsSaved: group_name: '_home_bichinh0_Movies_Old_School_WS_UNRATED_DVDRip_XViD-DVL_dvl-os_avi_734220288'
Debug: We have settings for this file!!!
Debug: Core::loadMediaInfo: '_home_bichinh0_Movies_Old_School_WS_UNRATED_DVDRip_XViD-DVL_dvl-os_avi_734220288'
Debug: MediaSettings::load
Debug: Media settings read
Debug: Core::playNewFile: volume: 40, old_volume: 40
Debug: Core::initPlaying
Debug: Core::startMplayer
Debug: Helper::setScreensaverEnabled: 0
Debug: Core::startMplayer: setting working directory to '/home/bichinh0/.smplayer/screenshots'
Debug: DesktopInfo::desktop_size: primary screen: 0
Debug: DesktopInfo::desktop_size: size of primary screen: 1280 x 800
Debug: DesktopInfo::desktop_size: size of screen: 1280 x 800
Debug: Core::startMplayer: command: 'mplayer -noquiet -nofs -sub-fuzziness 1 -identify -slave -zoom -nokeepaspect -input conf=/usr/share/smplayer/input.conf -stop-xscreensaver -wid 75497486 -colorkey 131586 -monitoraspect 1.6 -subfont-autoscale 1 -subfont-text-scale 5 -subcp ISO-8859-1 -subpos 100 -contrast 0 -brightness 0 -hue 0 -saturation 0 -osdlevel 0 -vf-add expand=osd=1 -noslices -vf-add screenshot -channels 2 /home/bichinh0/Movies/Old.School.WS.UNRATED.DVDRip.XViD-DVL/dvl-os.avi'
Debug: MplayerLayer::playingStarted
Debug: BaseGui::calculateDiff: diff_size: 0, 0
Debug: BaseGui::calculateDiff: diff_size set to: 0, 127
Debug: Core::tellmp: 'volume 40 1'
Debug: Playlist::addFiles
Debug:  * latest_dir: ''
Debug: MplayerProcess::parseLine: 'MPlayer dev-SVN-rUNKNOWN-4.1.2 (C) 2000-2007 MPlayer Team'
Debug: MplayerProcess::parseLine: MPlayer version found: dev
Warning: MplayerProcess::parseLine: unknown MPlayer version
Debug: MplayerProcess::parseLine: MPlayer SVN: 0
Debug: MplayerProcess::parseLine: 'CPU: AMD Turion(tm) 64 X2 Mobile Technology TL-56 (Family: 15, Model: 72, Stepping: 2)'
Debug: MplayerProcess::parseLine: 'CPUflags:  MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 1'
Debug: MplayerProcess::parseLine: 'Compiled with runtime CPU detection.'
Debug: MplayerProcess::parseLine: 'Can't open joystick device /dev/input/js0: No such file or directory'
Debug: MplayerProcess::parseLine: 'Can't init input joystick'
Debug: MplayerProcess::parseLine: 'mplayer: could not connect to socket'
Debug: MplayerProcess::parseLine: 'mplayer: No such file or directory'
Debug: MplayerProcess::parseLine: 'Failed to open LIRC support. You will not be able to use your remote control.'
Debug: MplayerProcess::parseLine: ''
Debug: MplayerProcess::parseLine: 'Playing /home/bichinh0/Movies/Old.School.WS.UNRATED.DVDRip.XViD-DVL/dvl-os.avi.'
Debug: MplayerProcess::parseLine: 'AVI file format detected.'
Debug: MplayerProcess::parseLine: 'ID_VIDEO_ID=0'
Debug: MplayerProcess::parseLine: '[aviheader] Video stream found, -vid 0'
Debug: MplayerProcess::parseLine: 'ID_AUDIO_ID=1'
Debug: MplayerProcess::parseLine: ID_AUDIO_ID: 1
Debug: MplayerProcess::parseLine: '[aviheader] Audio stream found, -aid 1'
Debug: MplayerProcess::parseLine: 'VIDEO:  [XVID]  608x256  24bpp  23.976 fps  924.0 kbps (112.8 kbyte/s)'
Debug: MplayerProcess::parseLine: 'Clip info:'
Debug: MplayerProcess::parseLine: ' Software: Nandub v1.0rc2'
Debug: MplayerProcess::parseLine: clip_software: 'Nandub v1.0rc2'
Debug: MplayerProcess::parseLine: 'ID_CLIP_INFO_NAME0=Software'
Debug: MplayerProcess::parseLine: 'ID_CLIP_INFO_VALUE0=Nandub v1.0rc2'
Debug: MplayerProcess::parseLine: 'ID_CLIP_INFO_N=1'
Debug: MplayerProcess::parseLine: 'ID_FILENAME=/home/bichinh0/Movies/Old.School.WS.UNRATED.DVDRip.XViD-DVL/dvl-os.avi'
Debug: MplayerProcess::parseLine: 'ID_DEMUXER=avi'
Debug: MplayerProcess::parseLine: 'ID_VIDEO_FORMAT=XVID'
Debug: MplayerProcess::parseLine: 'ID_VIDEO_BITRATE=924048'
Debug: MplayerProcess::parseLine: 'ID_VIDEO_WIDTH=608'
Debug: MplayerProcess::parseLine: md.video_width set to 608
Debug: MplayerProcess::parseLine: 'ID_VIDEO_HEIGHT=256'
Debug: MplayerProcess::parseLine: md.video_height set to 256
Debug: MplayerProcess::parseLine: 'ID_VIDEO_FPS=23.976'
Debug: MplayerProcess::parseLine: 'ID_VIDEO_ASPECT=0.0000'
Debug: MplayerProcess::parseLine: md.video_aspect set to 2.375000
Debug: MplayerProcess::parseLine: 'ID_AUDIO_FORMAT=85'
Debug: MplayerProcess::parseLine: 'ID_AUDIO_BITRATE=128944'
Debug: MplayerProcess::parseLine: 'ID_AUDIO_RATE=0'
Debug: MplayerProcess::parseLine: 'ID_AUDIO_NCH=0'
Debug: MplayerProcess::parseLine: 'ID_LENGTH=5511.59'
Debug: MplayerProcess::parseLine: md.duration set to 5511.590000
Debug: MplayerProcess::parseLine: 'xscreensaver_disable: Could not find XScreenSaver window.'
Debug: MplayerProcess::parseLine: 'Opening video filter: [screenshot]'
Debug: MplayerProcess::parseLine: 'MPlayer interrupted by signal 11 in module: init_video_filters'
Debug: MplayerProcess::parseLine: 'ID_SIGNAL=11'
Debug: MplayerProcess::parseLine: '- MPlayer crashed by bad usage of CPU/FPU/RAM.'
Debug: MplayerProcess::parseLine: '  Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and'
Debug: MplayerProcess::parseLine: '  disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.'
Debug: MplayerProcess::parseLine: '- MPlayer crashed. This shouldn't happen.'
Debug: MplayerProcess::parseLine: '  It can be a bug in the MPlayer code _or_ in your drivers _or_ in your'
Debug: MplayerProcess::parseLine: '  gcc version. If you think it's MPlayer's fault, please read'
Debug: MplayerProcess::parseLine: '  DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and'
Debug: MplayerProcess::parseLine: '  won't help unless you provide this information when reporting a possible bug.'
Debug: MyProcess::procFinished
Debug: MyProcess::procFinished: Bytes available: 0
Debug: MplayerProcess::processFinished
Debug: Core::processFinished
Debug: Helper::setScreensaverEnabled: 1
Debug: Core::processFinished: we_are_restarting: 0
Debug: Core::processFinished: play has finished!
Debug:  exit_status: 0
Debug: MplayerLayer::playingStopped
Anything stand out to anyone? Mplayer crashed there in the middle, but it seems to work fine, just Mplayer. :(
chickpea
Re: SMplayer troubles
Postby Fitzcarraldo » Wed Feb 06, 2008 9:02
smplayer-0.5.50 comes installed with SL 3.4f, and the ebuild was in the SL overlay because an ebuild for SMPlayer was not in the Portage repo. However, I discovered yesterday that the smplayer-0.5.62 ebuild has recently been added to the Portage repo., so the available versions are now:
# eix smplayer
[I] media-video/smplayer
Available versions: (~)0.5.59[1] (~)0.5.62 {linguas_bg linguas_cs linguas_de linguas_en_US linguas_es linguas_fr linguas_hu linguas_it linguas_ja linguas_ka linguas_nl linguas_pl linguas_pt_BR linguas_pt_PT linguas_ro linguas_ru linguas_sk linguas_sr linguas_sv linguas_tr linguas_uk linguas_zh_CN linguas_zh_TW}
Installed versions: 0.5.62(21:32:18 05/02/08)(-linguas_bg -linguas_cs -linguas_de -linguas_en_US -linguas_es -linguas_fr -linguas_hu -linguas_it -linguas_ja -linguas_ka -linguas_nl -linguas_pl -linguas_pt_BR -linguas_pt_PT -linguas_ro -linguas_ru -linguas_sk -linguas_sr -linguas_sv -linguas_tr -linguas_uk -linguas_zh_CN -linguas_zh_TW)
Homepage: http://smplayer.sourceforge.net
Description: Great front-end for mplayer written in Qt4
[1] "sabayon" /usr/portage/local/layman/sabayon
As shown above, the ebuild for smplayer-0.5.59 is in the SL overlay, whereas the ebuild for smplayer-0.5.62 is in the Portage tree.
Anyway, I just did an "emerge -1v smplayer" to get rid of smplayer-0.5.50 and install smplayer-0.5.62.
However, when I ran the new version of SMPlayer and tried to play a DivX video, nothing was displayed and the message displayed in a Terminal window was along the lines of:
ID_SIGNAL=11
But yet the video plays fine if I use MPlayer! So I thought something strange was going on with SMPlayer, which is just a front-end to MPlayer. I solved it just be doing a little configuring of SMPlayer:
1. 'Options > Preferences', clicked on the 'General' tab and I cleared the box 'Folder for storing screenshots:' (it did have "/home/fitzcarraldo/.smplayer/screenshots" in it) and clicked on 'Apply'.
2. 'Options > Preferences', clicked on the 'General' tab and I selected the Output drivers | Video as "x11" and clicked on 'Apply'.
3. 'Options > View info and properties...', clicked on 'Demuxer' tab and selected 'avi - AVI demuxer (AVI files, including non interleaved files)' and clicked on 'Apply'.
4. 'Options > View info and properties...', clicked on 'Video_codec' tab and select 'ffodivx - FFmpeg MPEG-4 [mpeg4]' and clicked on 'Apply'.
5. 'Options > View info and properties...', clicked on 'Audio_codec' tab and selected 'mp3 - mp3lib MPEG layer-2, layer-3' and clicked on 'Apply'.
And now the new version of SMPlayer plays all my DivX files.
Postby chickpea » Wed Feb 06, 2008 15:44
Thanks fitz. I'll see if this solves my issues as well. I also installed the portage smplayer, not the SL overlay version. Which has lead to these issues. So it seems to be the same issue you experienced.
Will report back.
chickpea
