mysql error configuring ...
Postby suryx » Tue Jan 22, 2008 10:36
i have new this system ... and i had this errror :
localhost ~ # emerge --config =dev-db/mysql-5.0.44
Configuring pkg...
 * MySQL MY_DATADIR is /var/lib/mysql
 * Previous datadir found, it's YOUR job to change
 * ownership and take care of it
 * Creating the mysql database and setting proper
 * permissions on it ...
 * Insert a password for the mysql 'root' user
 * Avoid ["'\_%] characters in the password
 * Retype the password
!!! ERROR: dev-db/mysql-5.0.44 failed.
Call stack:
  ebuild.sh, line 1613:   Called qa_call 'pkg_config'
  ebuild.sh, line 44:   Called pkg_config
  ebuild.sh, line 1322:   Called mysql_pkg_config
  mysql.eclass, line 819:   Called die
!!! MySQL databases not installed
!!! If you need support, post the topmost build error, and the call stack if relevant.
!!! A complete build log is located at '/var/tmp/portage/dev-db/mysql-5.0.44/temp/build.log'.
tooo second error :
localhost ~ # /etc/init.d/mysql start
 * Starting mysql ...
 * Starting mysql (/etc/mysql/my.cnf)
 * MySQL NOT started (1)        [ !! ]
localhost ~ #
and my my.cnf :
# /etc/mysql/my.cnf: The global mysql configuration file.
# $Header: /var/cvsroot/gentoo-x86/dev-db/mysql/files/my.cnf-4.1,v 1.3 2006/05/05 19:51:40 chtekk Exp $
# The following options will be passed to all MySQL clients
[client]
#password                                       = your_password
port                                            = 3306
socket                                          = /var/run/mysqld/mysqld.sock
[mysql]
character-sets-dir=/usr/share/mysql/charsets
default-character-set=utf8
[mysqladmin]
[mysqlcheck]
[mysqldump]
[mysqlimport]
[mysqlshow]
[myisamchk]
[myisampack]
# use [safe_mysqld] with mysql-3
[mysqld_safe]
err-log                                         = /var/log/mysql/mysql.err
# add a section [mysqld-4.1] or [mysqld-5.0] for specific configurations
[mysqld]
character-set-server            = utf8
default-character-set           = utf8
user                                            = mysql
port                                            = 3306
pid-file                                        = /var/run/mysqld/mysqld.pid
log-error                                       = /var/log/mysql/mysqld.err
basedir                                         = /usr
datadir                                         = /var/lib/mysql
skip-locking
key_buffer                                      = 16M
max_allowed_packet                      = 1M
table_cache                             = 64
sort_buffer_size                        = 512K
net_buffer_length                       = 8K
read_buffer_size                        = 256K
read_rnd_buffer_size            = 512K
myisam_sort_buffer_size         = 8M
language                                        = /usr/share/mysql/english
# security:
# using "localhost" in connects uses sockets by default
# skip-networking
bind-address                            = 127.0.0.1
log-bin
server-id                                       = 1
max_binlog_size = 128M
max_binlog_cache_size = 256M
# point the following paths to different dedicated disks
tmpdir                                          = /tmp/
#log-update                             = /path-to-dedicated-directory/hostname
# you need the debug USE flag enabled to use the following directives,
# if needed, uncomment them, start the server and issue
# #tail -f /tmp/mysqld.sql /tmp/mysqld.trace
# this will show you *exactly* what's happening in your server ;)
#log                                            = /tmp/mysqld.sql
#gdb
#debug                                          = d:t:i:o,/tmp/mysqld.trace
#one-thread
# uncomment the following directives if you are using BDB tables
#bdb_cache_size                         = 4M
#bdb_max_lock                           = 10000
# the following is the InnoDB configuration
# if you wish to disable innodb instead
# uncomment just the next line
#skip-innodb
# the rest of the innodb config follows:
# don't eat too much memory, we're trying to be safe on 64Mb boxes
# you might want to bump this up a bit on boxes with more RAM
innodb_buffer_pool_size = 16M
# this is the default, increase it if you have lots of tables
innodb_additional_mem_pool_size = 2M
# i'd like to use /var/lib/mysql/innodb, but that is seen as a database :-(
# and upstream wants things to be under /var/lib/mysql/, so that's the route
# we have to take for the moment
#innodb_data_home_dir           = /var/lib/mysql/
#innodb_log_arch_dir            = /var/lib/mysql/
#innodb_log_group_home_dir      = /var/lib/mysql/
# you may wish to change this size to be more suitable for your system
# the max is there to avoid run-away growth on your machine
innodb_data_file_path = ibdata1:10M:autoextend:max:128M
# we keep this at around 25% of of innodb_buffer_pool_size
# sensible values range from 1MB to (1/innodb_log_files_in_group*innodb_buffer_pool_size)
innodb_log_file_size = 5M
# this is the default, increase it if you have very large transactions going on
innodb_log_buffer_size = 8M
# this is the default and won't hurt you
# you shouldn't need to tweak it
set-variable = innodb_log_files_in_group=2
# see the innodb config docs, the other options are not always safe
innodb_flush_log_at_trx_commit = 1
innodb_lock_wait_timeout = 50
[mysqldump]
quick
max_allowed_packet                      = 16M
[mysql]
# uncomment the next directive if you are not familiar with SQL
#safe-updates
[isamchk]
key_buffer                                      = 20M
sort_buffer_size                        = 20M
read_buffer                             = 2M
write_buffer                            = 2M
[myisamchk]
key_buffer                                      = 20M
read_buffer                             = 2M
write_buffer                            = 2M
[mysqlhotcopy]
interactive-timeout
please .. help . how good to configure .. sry bad my english ;p
suryx
Re: mysql error configuring ...
Postby joost » Tue Jan 22, 2008 11:57
Maybe post this file:
/var/log/mysql/mysql.err or some other log file in /var/log with mysql in its name.
Postby suryx » Tue Jan 22, 2008 13:21
080123 10:32:48 [Warning] No argument was provided to --log-bin, and --log-bin-index was not used; so replication may break when this MySQL server acts as a master and has his hostname changed!! Please use '--log-bin=/var/run/mysqld/mysqld-bin' to avoid this problem.
/usr/sbin/mysqld: File '/var/run/mysqld/mysqld-bin.index' not found (Errcode: 13)
080123 10:32:48 [ERROR] Aborting
080123 10:32:48 [Note] /usr/sbin/mysqld: Shutdown complete
This is ...
suryx
Postby suryx » Tue Jan 22, 2008 13:55
thank joost ! work me ;p
suryx
