How to Install ALSA 1.0.15
Postby sajellish » Sun Jan 20, 2008 17:17
I am new to this whole gentoo-emerge thingy. I had a lot of trouble configuring sound on my HP DV6616TX laptop on SUSE. Finally it boiled down to alsa 1.0.15 version. That is the only version of alsa that works on my system. I tried to use emerge, but the installation kept failing. Can someone suggest me a way. have Sabayon mini 3.4 by the way. The exact command and the output are as under............
Also if someone can suggest a better way of installing ALSA 1.0.15, it would be great.
# emerge -av =media-sound/alsa-driver-1.0.15
[ebuild N ] media-sound/alsa-driver-1.0.15 USE="midi -debug -oss" ALSA_CARDS="ali5451 als4000 atiixp atiixp-modem bt87x ca0106 cmipci emu10k1 emu10k1x ens1370 ens1371 es1938 es1968 fm801 hda-intel intel8x0 intel8x0m maestro3 trident usb-audio via82xx via82xx-modem ymfpci -ad1816a -ad1848 -ad1848-lib -ad1889 -adlib -als100 -als300 (-aoa) (-aoa-fabric-layout) (-aoa-onyx) (-aoa-soundbus) (-aoa-soundbus-i2s) (-aoa-tas) (-aoa-toonie) (-armaaci) -asihpi (-at91-soc) (-at91-soc-eti-b1-wm8731) (-au1x00) -au8810 -au8820 -au8830 -azt2320 -azt3328 -cmi8330 -cs4231 -cs4231-lib -cs4232 -cs4236 -cs4281 -cs46xx -cs5535audio -darla20 -darla24 -dt019x -dummy -echo3g -es1688 -es18xx -es968 -fm801-tea575x -gina20 -gina24 -gusclassic -gusextreme -gusmax (-harmony) -hdsp -hdspm -ice1712 -ice1724 -indigo -indigodj -indigoio -interwave -interwave-stb -korg1212 -layla20 -layla24 -loopback -mia -miro -mixart -mona -mpu401 -msnd-pinnacle -mtpav -mts64 -nm256 -opl3sa2 -opti92x-ad1848 -opti92x-cs4231 -opti93x -pc98-cs4232 -pcsp -pcxhr -pdaudiocf -pdplus -portman2x4 (-powermac) (-pxa2xx-i2sound) (-pxa2xx-soc) (-pxa2xx-soc-corgi) (-pxa2xx-soc-poodle) (-pxa2xx-soc-spitz) (-pxa2xx-soc-tosa) -riptide -rme32 -rme96 -rme9652 -s3c2410 -sa11xx-uda1341 -sb16 -sb8 -sbawe -seq-dummy -serial-u16550 -sgalaxy -soc -sonicvibes -sscape (-sun-amd7930) (-sun-cs4231) (-sun-dbri) -usb-usx2y -virmidi -vx222 -vxpocket -wavefront" 0 kB [0]
Total: 1 package (1 new), Size of downloads: 0 kB
Portage tree and overlays:
[0] /usr/portage
Would you like to merge these packages? [Yes/No] yes
>>> Verifying ebuild Manifests...
>>> Emerging (1 of 1) media-sound/alsa-driver-1.0.15 to /
* alsa-driver-1.0.15.tar.bz2 RMD160 ;-) ... [ ok ]
* alsa-driver-1.0.15.tar.bz2 SHA1 ;-) ... [ ok ]
* alsa-driver-1.0.15.tar.bz2 SHA256 ;-) ... [ ok ]
* alsa-driver-1.0.15.tar.bz2 size ;-) ... [ ok ]
* checking ebuild checksums ;-) ... [ ok ]
* checking auxfile checksums ;-) ... [ ok ]
* checking miscfile checksums ;-) ... [ ok ]
* checking alsa-driver-1.0.15.tar.bz2 ;-) ... [ ok ]
* Determining the location of the kernel source code
* Found kernel source directory:
* /usr/src/linux
* Could not find a usable .config in the kernel source directory.
* Please ensure that /usr/src/linux points to a configured set of Linux sources.
* If you are using KBUILD_OUTPUT, please set the environment var so that
* it points to the necessary object directory so that it might find .config.
* ERROR: media-sound/alsa-driver-1.0.15 failed.
* Call stack:
* ebuild.sh, line 1664: Called dyn_setup
* ebuild.sh, line 719: Called qa_call 'pkg_setup'
* ebuild.sh, line 44: Called pkg_setup
* alsa-driver-1.0.15.ebuild, line 104: Called linux-mod_pkg_setup
* linux-mod.eclass, line 465: Called linux-info_pkg_setup
* linux-info.eclass, line 558: Called die
* Unable to calculate Linux Kernel version
* A complete build log is located at '/var/tmp/portage/media-sound/alsa-driver-1.0.15/temp/build.log'.
* Messages for package media-sound/alsa-driver-1.0.15:
* Call stack:
sajellish
Re: How to Install ALSA 1.0.15
Postby wolfden » Sun Jan 20, 2008 17:26
You can't install alsa-drivers when alsa is built into the kernel, recompile kernel without alsa than install alsa-drivers
http://www.gentoo.org/doc/en/alsa-guide.xml
With mini it doesn't come with the sources so you have to install em before installing packages.
http://wiki.sabayonlinux.org/index.php? ... el_version
