Mozilla Firefox and Thunderbird not working
Postby kettlehead » Tue Jan 08, 2008 6:32
Hi everyone
I am a real newbie to all things linux, but I had had such good reports about sabayon I though I would give it a try.
Because I'm not sure what info people need to help me troubleshoot this problem I thought I would start very basically. In other words when I try to start either Firefox or Thunderbird the bouncing Icon appears for a few seconds and then nothing. The mouse arrow returns and nothing else happens,
Everything else appears to be working normally.
Any trouble shooting tips or a way in which i can "reset" both firefox and thunderbird would be great.
I am using mini edition 3.4.
Thank you
kettlehead
Re: Mozilla Firefox and Thunderbird not working
Postby wolfden » Tue Jan 08, 2008 7:26
try
emerge mozilla-firefox-bin mozilla-thunderbird-bin
if that don't work than run them from konsole and see what errors spit out.
Postby kettlehead » Tue Jan 08, 2008 9:54
Thanks for the help Wolfden
I ran the command in konsole anyway and everything appears to be OK, i.e no errors. However neither of the two applications want to run!?! :(
Any other suggestion appreciated.
>>> Original instance of package unmerged safely.
* For enigmail, please see instructions at
* http://enigmail.mozdev.org/
>>> Regenerating /etc/ld.so.cache...
>>> mail-client/mozilla-thunderbird-bin-2.0.0.9 merged.
>>> No packages selected for removal by clean
>>> Auto-cleaning packages...
>>> No outdated packages were found on your system.
* Messages for package mail-client/mozilla-thunderbird-bin-2.0.0.9:
* GNU info directory index is up-to-date.
kettlehead
Postby wolfden » Tue Jan 08, 2008 10:08
start them from konsole and see what the error is.
open konsole
than run the command: firefox
Postby kettlehead » Tue Jan 08, 2008 12:56
Wolfden
Thanks for the help. Here are the error messages
When I ran firefox in Konsole the following came up and also Firefox started!
No running windows found
/usr/libexec/gconfd-2: /usr/libexec/gconfd-2: cannot execute binary file
GConf Error: Failed to contact configuration server; some possible causes are that you need to enable TCP/IP networking for ORBit, or you have stale NFS locks due to a system crash. See http://www.gnome.org/projects/gconf/ for information. (Details - 2: IOR file '/tmp/gconfd-root/lock/ior' not opened successfully, no gconfd located: No such file or directory)
(Gecko:12180): libgnomevfs-WARNING **: Could not create per-user Gnome application-registry directory: /root/.gnome/application-info
(Gecko:12180): libgnomevfs-WARNING **: Deprecated function. User modifications to the MIME database are no longer supported.
(Gecko:12180): libgnomevfs-WARNING **: Cannot open '/root/.gnome/application-info/user.applications' for writing
And when I ran Thunderbird in Konsole the following came up and also Thunderbird started
GConf Error: Failed to contact configuration server; some possible causes are th at you need to enable TCP/IP networking for ORBit, or you have stale NFS locks d ue to a system crash. See http://www.gnome.org/projects/gconf/ for information. (Details - 2: IOR file '/tmp/gconfd-root/lock/ior' not opened successfully, no gconfd located: No such file or directory)
Registering Enigmail account manager extension.
Enigmail account manager extension registered.
GConf Error: Failed to contact configuration server; some possible causes are that you need to enable TCP/IP networking for O RBit, or you have stale NFS locks due to a system crash. See http://www.gnome.org/projects/gconf/ for information. (Details - 2: IOR file '/tmp/gconfd-root/lock/ior' not opened successfully, no gconfd located: No such file or directory)
*** cal_calendar_schema_version not found; initializing storage provider tables
cal_events
cal_todos
cal_attendees
cal_recurrence
cal_properties
kettlehead
Postby wolfden » Tue Jan 08, 2008 13:35
hmmmm weird,
so does it work now when you click on their icons? If not, use the menu editor and see what in the world the icons are point at. Alt F2 should open a run box and you should be able to type them in there to run em too.
Postby joost » Tue Jan 08, 2008 14:56
Might wanna try the distro binaries:
equo update
equo install mozilla-firefox
equo install mozilla-thunderbird
And maybe and perhaps run:
equo deptest
Just a thought.
I've installed firefox through equo on the mini, and it worked out fine.
Postby kettlehead » Tue Jan 08, 2008 21:16
Hi
I've tried a few of the options you guys have suggested and the only real progress I have had is that when I run Firefox from the Run Command I get the following Error Message
Error launching firefox-bin:
There are files in your profile that are owned by a user other than
tim. firefox-bin can't execute in this condition. Here are some of
the files that I found:
/home/tim/.mozilla/firefox/uq3g6doz.default/prefs.js
You can fix this problem by running the following:
su -c 'chown -R tim:tim /home/tim/.mozilla'
Tried following the instructions i.e ran the command, but still no joy
Update: Firefox is running normally now, however Thunderbird is not. I get the same error message as described above except the reference to the file is
/home/tim/.thunderbird/su20ihfo.default/prefs.js
Any other ideas. And thanks again for all the help
kettlehead
Postby kettlehead » Wed Jan 09, 2008 23:51
I've been defeated. I cannot, for the life of me get thunderbird to work so I have saved off the files I need and blown sabayon away and reinstalled.
Hopefully this time round I'll keep to what I understand and not mess the thing up.
thanks to those guys that helped. I appreciate your time.
kettle
kettlehead
