No drives in SuSE menu after update
Postby Tautrimas » Wed Jan 02, 2008 10:51
I updated some packages through equo (kde, maybe hal and some others) and now I don't see any of my partitions in the menu in Computer section. I also can't see any partitions in system:/media.
Tautrimas
Re: No drives in SuSE menu after update
Postby wolfden » Wed Jan 02, 2008 11:02
well check your version of hal, if it is 0.5.10 than downgrade it to previous version as the new hal is broke.
Postby Tautrimas » Wed Jan 02, 2008 11:15
Well, it's 0.5.9.1-r7. Updating to r8, but I don't expect anything.
* EDIT:
Of cource, no difference after update.
Tautrimas
Postby wolfden » Wed Jan 02, 2008 11:29
hmmmm - either of those version should be good.
so your /media folder is empty?
Postby Tautrimas » Wed Jan 02, 2008 11:49
$ ls /media
floppy  h  sr0
I used h for some playing some time ago. Actually, /media is always looking like this, unless I open partition in "system:/media" or in Computer menu. But those two appears to be empty. Neither NTFS nor EXT3 partitions appear there.
Tautrimas
Postby wolfden » Wed Jan 02, 2008 11:53
when u installed hal-0.5.9.1-r8 did u use equo or emerge
I would use emerge to reinstall it and than make sure you etc-update your config files and than you may have to /etc/init.d/hald restart
It's got to be something with hal
Postby Tautrimas » Wed Jan 02, 2008 12:11
emerge hal && cfg-update -u && /etc/init.d/hald restart
Now, system:/media is showing what it is supposed to show. After Ctrl+Alt+Backsps menu is still empty. Half a problem solved (:
Another question: when could equo be used? It's fast, but as I see, not ultra reliable. Updating compiz also failed using equo.
Tautrimas
Postby wolfden » Wed Jan 02, 2008 12:17
Keep in mind that equo just reached beta stage with the release of beta 3.5 and make sure you are keeping up with svn equo as it changes a lot. I don't use the suse kicker so not sure how that all works.
You said u updated a bunch of stuff - wonder if re-emerging the kicker will fix it. ??
Postby Tautrimas » Wed Jan 02, 2008 12:26
Ok. I'll try your peaces of advice.
Tautrimas
Postby Tautrimas » Wed Jan 02, 2008 13:54
Ok, synched and did:
emerge kicker
. Now, no kicker at all... There is an option to use SUSE kicker from the panel options but nothing happens upon pressing APPLY. Oh, yeah, happens: all programs from topmost taskbar disappears (:
And one more thing: I didn't make out how to compile equo from svn. Anyways, thank's for your helping, wolfden!
Tautrimas
