icecast fails to start [Solved]
Postby jspeybro » Fri Dec 28, 2007 14:40
I'm having a problem with icecast.
I emerged icecast, mpd, phpmp, apache2 and php.
mpd runs fine, phpmp also. I can listen to the music on the local soundcard.
Icecast however fails to start.
if I do /etc/init.d/icecast start, I get a message that it is starting, followed by [OK].
if I then do /etc/init.d/icecast status, it tells me that icecast is stopped.
I don't know if there is a logfile somewhere for icecast.
If I connect to localhost:8000, it fails to find the page which is obvious due to the fact that icecast is not running.
any ideas where to start looking for the problem?
regards,
Johan
jspeybro
Re: icecast fails to start
Postby wolfden » Fri Dec 28, 2007 14:43
are you following:
http://gentoo-wiki.com/HOWTO_Icecast_OG ... _streaming
/var/log/icecast/error.log
Postby jspeybro » Fri Dec 28, 2007 14:52
I found the sollution.
I ran icecast -c /etc/icecast2/icecast.xml and this revieled a permission problem with the log dir.
this command fixed the issue:
chown icecast:nogroup /var/log/icecast
jspeybro
