I done emerge --sync, emerge portage, and all such things before emerging them.
But no one runs. Even in root.
Linuxdcpp works, but I want to try others.
This is what was written in portato console after emerging dbhub :
>>> Verifying ebuild Manifests...
>>> Emerging (1 of 1) net-p2p/dbhub-0.450 to /
* dbhub-0.450.tar.gz RMD160 SHA1 SHA256 size
* checking ebuild checksums
* checking auxfile checksums
* checking miscfile checksums
* checking dbhub-0.450.tar.gz
>>> Unpacking source...
>>> Unpacking dbhub-0.450.tar.gz to /var/tmp/portage/net-p2p/dbhub-0.450/work
* Applying dbhub-gentoo.patch ... [ ok ]
>>> Source unpacked.
>>> Compiling source in /var/tmp/portage/net-p2p/dbhub-0.450/work/dbhub-0.450 ...
* econf: updating dbhub-0.450/config.guess with /usr/share/gnuconfig/config.guess
* econf: updating dbhub-0.450/config.sub with /usr/share/gnuconfig/config.sub
./configure --prefix=/usr --host=i586-pc-linux-gnu --mandir=/usr/share/man --infodir=/usr/share/info --datadir=/usr/share --sysconfdir=/etc --localstatedir=/var/lib --enable-lang --enable-perl --build=i586-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
/var/tmp/portage/net-p2p/dbhub-0.450/work/dbhub-0.450/missing: Unknown `--run' option
Try `/var/tmp/portage/net-p2p/dbhub-0.450/work/dbhub-0.450/missing --help' for more information
configure: WARNING: `missing' script is too old or missing
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for i586-pc-linux-gnu-gcc... i586-pc-linux-gnu-gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether i586-pc-linux-gnu-gcc accepts -g... yes
checking for i586-pc-linux-gnu-gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of i586-pc-linux-gnu-gcc... gcc3
checking for socket in -lsocket... no
checking for gethostbyname in -lnsl... yes
checking for crypt in -lcrypt... yes
checking for crypt in -lcrypto... yes
checking how to run the C preprocessor... i586-pc-linux-gnu-gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking crypt.h usability... yes
checking crypt.h presence... yes
checking for crypt.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking sys/poll.h usability... yes
checking sys/poll.h presence... yes
checking for sys/poll.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking for unistd.h... (cached) yes
checking for an ANSI C-conforming const... yes
checking whether time.h and sys/time.h may both be included... yes
checking for mode_t... yes
checking for pid_t... yes
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking whether struct tm is in sys/time.h or time.h... time.h
checking for size_t... yes
checking for uid_t in sys/types.h... yes
checking for vprintf... yes
checking for _doprnt... no
checking for gethostname... yes
checking for mkdir... yes
checking for poll... yes
checking for select... yes
checking for socket... yes
checking for strstr... yes
checking for strtoll... yes
checking for strtoq... yes
checking for getcwd... yes
checking for gethostbyaddr... yes
checking for gethostbyname... yes
checking for inet_ntoa... yes
checking for memset... yes
checking for strcasecmp... yes
checking for strchr... yes
checking for strerror... yes
checking for strncasecmp... yes
checking for strrchr... yes
checking whether closedir returns void... no
checking for stdlib.h... (cached) yes
checking for GNU libc compatible realloc... yes
checking for sys/select.h... (cached) yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking types of arguments for select... int,fd_set *,struct timeval *
Language support is disabled
checking for perl... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking for alarm... yes
checking vfork.h usability... no
checking vfork.h presence... no
checking for vfork.h... no
checking for fork... yes
checking for vfork... yes
checking for working fork... yes
checking for working vfork... (cached) yes
checking for GNU libc compatible malloc... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating config.h
config.status: executing depfiles commands
*** Type "gmake" to build dbhub ***
*** If "gmake" does not work, try "make" ***
Making all in src
>>> Source compiled.
>>> Test phase [not enabled]: net-p2p/dbhub-0.450
>>> Install dbhub-0.450 into /var/tmp/portage/net-p2p/dbhub-0.450/image/ category net-p2p
Making install in src
/usr/bin/install -c 'dbhub' '/var/tmp/portage/net-p2p/dbhub-0.450/image//usr/bin/dbhub'
>>> Completed installing dbhub-0.450 into /var/tmp/portage/net-p2p/dbhub-0.450/image/
* QA Notice: Pre-stripped files found:
* /var/tmp/portage/net-p2p/dbhub-0.450/image/usr/bin/dbhub
* checking 1 files for package collisions
>>> Merging net-p2p/dbhub-0.450 to /
--- /usr/
--- /usr/bin/
>>> /usr/bin/dbhub
>>> Safely unmerging already-installed instance...
No package files given... Grabbing a set.
--- replaced obj /usr/bin/dbhub
--- replaced dir /usr/bin
>>> Original instance of package unmerged safely.
>>> net-p2p/dbhub-0.450 merged.
>>> No packages selected for removal by clean
>>> Auto-cleaning packages...
>>> No outdated packages were found on your system.
* GNU info directory index is up-to-date.
What is wrong?
