I see dead terminals... or living terminals..
Postby cmolson6 » Mon Dec 17, 2007 17:10
Hey I am not sure if this is the right spot but here goes:
first my system specs:
Core 2 duo 2.13Ghz
4GB ram
Sabayon (latest) linux 64bit
2 x ATI x1950 pro 256mb video cards
1 x ATI mach64 (dunno how much ram)
I spent the past 16 hours getting a multi-seat setup on my PC. I tried getting the two PCIe x1950's working, but couldn't so I had an old mach64 lying around I decided to try.
I got it setup now after many problems (well problems because I didn't know what I was doing really)
So I have compiz on my one x1950 running and my old mach64 with a regular kde window manager..
Problem is that I can see the main tty (terminal) behind the screen.. when I move my mouse (either seats mouse) it creates artifacts on the screen which are not very nice. It looks exactly like there is a small terminal at the top of my screen, and when I move the mouse that same little rectangle moves around as if I was in a terminal. It also has a small square blinking like it does in the terminal...
Why is this happening? is my display sharing a tty or something with the main terminal? Please let me know if you need more info to help with this.
Thanks!
Here is my xorg.conf
# Server flags section.  This contains various server-wide Options.
# Input devices
# Core keyboard's InputDevice section
# Core Pointer's InputDevice section
# Monitor section
# Any number of monitor sections may be present
# Graphics device section
# Any number of graphics device sections may be present
# Screen sections.
Section "Module"
        Load  "dbe"
        Load  "i2c"
        Load  "glx"
        Load  "ddc"
        Load  "type1"
        Load  "freetype"
        Load  "extmod"
        Load  "synaptics"
        Load  "vbe"
        Load  "dri"
EndSection
Section   "ServerLayout"
   Identifier   "alltogether"
   Screen 0 "aticonfig-Screen[0]" LeftOf "ATIScreen"
   Screen   1 "ATIScreen" RightOf "aticonfig-Screen[0]"
   InputDevice   "Mouse1"
   InputDevice   "Mouse2"
   InputDevice   "Keyboard1"
   InputDevice   "Keyboard2"
EndSection
        Identifier     "Seat.0"
        Option "aiglx" "true"
EndSection
   Identifier   "Seat.1"
   #Screen 1   "aticonfig-Screen[1]"
EndSection
Section "Files"
    #FontPath   "/usr/share/fonts/local/"
        FontPath     "/usr/share/fonts/misc/"
        FontPath     "/usr/share/fonts/Type1/"
        FontPath     "/usr/share/fonts/TTF/"
        FontPath     "/usr/share/fonts/75dpi/"
        FontPath     "/usr/share/fonts/100dpi/"
        FontPath     "/usr/share/fonts/corefonts"
EndSection
Section "ServerFlags"
        Option      "AllowMouseOpenFail" "on"
        Option      "IgnoreABI"  "on"
   Option       "DontVTSwitch"
   Option      "HandleSpecialKeys"   "Always"
   Option        "Xinerama"   "0"
   Option "DontZap" "yes"
EndSection
Section "InputDevice"
        Identifier  "Keyboard1"
        Driver      "evdev"
   #Option   "Protocol"   "evdev"
   Option   "Device"   "/dev/input/event6"
        Option          "XkbRules"      "xorg"
        Option          "XkbModel"      "pc104"
        Option          "XkbLayout"     "us"
        Option          "CoreKeyboard"
EndSection
        Identifier  "Mouse1"
   Driver   "mouse"
   Option   "Device"   "/dev/input/mouse1"
        Option          "CorePointer"
        Option          "ZAxisMapping"          "4 5"
EndSection
   Identifier   "Keyboard2"
   Driver   "evdev"
   Option   "Device"   "/dev/input/event4"
   Option      "XkbModel"      "evdev"
EndSection
   Identifier   "Mouse2"
   Driver   "mouse"
   Option   "Device"   "/dev/input/mouse2"
EndSection
Section "Monitor"
       #Option      "DPMS"
        Identifier   "Generic Monitor"
        HorizSync    28.0 - 80.0
        VertRefresh  43.0 - 60.0
EndSection
Section "Monitor"
        Identifier   "aticonfig-Monitor[0]"
        Option      "VendorName" "ATI Proprietary Driver"
        Option      "ModelName" "Generic Autodetecting Monitor"
        Option      "DPMS" "true"
EndSection
Section "Monitor"
        Identifier   "aticonfig-Monitor[1]"
EndSection
Section   "Device"
   Identifier   "ATICard"
   Driver   "ati"
   BusID   "PCI:1:2:0"
EndSection
Section "Device"
        Identifier  "aticonfig-Device[1]"
        Driver      "fglrx"
   Option   "DRI" "true"
   #Option   "NoInt10" "Yes"
       Option "VideoOverlay" "on"
        Option "OpenGLOverlay" "off"
       Option "TexturedVideo" "on"
        Option "DRI"  "true"
      Option "UseFastTLS" "1"
        Option     "AccelMethod" "EXA"
   BusID "PCI:6:0:0"
EndSection
Section "Device"
        Identifier  "aticonfig-Device[0]"
        Driver      "fglrx"
   #Option "XAANoOffscreenPixmaps" "true"
        #Option "BusType" "PCI"
       #Option "ColorTiling" "on"
        #Option "EnablePageFlip" "on"
        Option "DRI"  "true"
   #Option "RenderAccel" "on"
   BusID "PCI:7:0:0"
EndSection
Section   "Screen"
   Identifier   "ATIScreen"
   Device      "ATICard"
   Monitor      "Generic Monitor"
   DefaultDepth   8
   SubSection "Display"
      Modes   "1024x768" "800x600" "640x480"
      Depth   8
   EndSubSection
EndSection
Section "Screen"
   #Option "AddARGBGLXVisuals" "true"
        Identifier "aticonfig-Screen[0]"
        Device     "aticonfig-Device[0]"
        Monitor    "aticonfig-Monitor[0]"
        DefaultDepth     24
                Depth     24
        EndSubSection
EndSection
Section "Screen"
        Identifier "aticonfig-Screen[1]"
        Device     "aticonfig-Device[1]"
        Monitor    "aticonfig-Monitor[1]"
        DefaultDepth     24
                Depth     24
        EndSubSection
EndSection
Section "Extensions"
   Option "Composite" "Enable"
EndSection
Section "DRI"
        Mode         0666
EndSection
My messed up desktop
cmolson6
Re: I see dead terminals... or living terminals..
Postby wolfden » Tue Dec 18, 2007 6:51
:lol:
I must say that is different, looks like video card issues
