Boot Up Manager For KDE
Re: Boot Up Manager For KDE
Postby Stupot » Sat Nov 10, 2007 19:04
There is a folder that starts up applications upon login located at /home/<USER>/kde/Autostart . Just drag and drop links to applications you want to start up into that folder.
Postby wolfden » Sun Nov 11, 2007 3:26
use
rc-update show
to see the list than
rc-update del foo
as root of course
3rd party ebuild GUI
http://gentoo-wiki.com/HOWTO_Manage_ser ... modern_GUI
Postby tekwyzrd » Fri Nov 16, 2007 2:22
To disable autostart of unneeded items like ksynaptics and kbluetooth I shut down the unwanted apps (right click tray icon, select exit), created /usr/shared/autostart-disabled (I used File Manager - Super User Mode), and moved the .desktop files for the apps I don't want to autostart from /usr/shared/autostart to /usr/shared/autostart-disabled. Should I ever decide I need them I can move them back to their original location.
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws.
Douglas Adams (1952 - 2001)
tekwyzrd
