Problem:genkernel 3.4.9-pre7+8 and sabayon-sources-2.6.23-r1
Postby tekwyzrd » Fri Nov 09, 2007 19:32
Using genkernel 3.4.9 pre7 installed by emerge genkernel and upgrade to genkernel 3.4.9-pre8 cause kernel build to die with
Linux Kernel 2.6.23-sabayon-r1 for x86...
* kernel: >> Running mrproper...
* ERROR: Failed to compile the "mrproper" target...
* -- Grepping log... --
Makefile:492: /usr/src/linux-2.6.23-sabayon-r1/arch/x86/Makefile: No such file or directory
make: *** No rule to make target `/usr/src/linux-2.6.23-sabayon-r1/arch/x86/Makefile'. Stop.
* Gentoo Linux Genkernel; Version 3.4.9_pre8
* Running with options: --kernel-config=/usr/src/config --menuconfig --bootloader=grub --splash=sabayon all
* -- End log... --
* Please consult /var/log/genkernel.log for more information and any
* errors that were reported above.
I have downgraded to genkernel 3.4.8-r4 and it's currently hard at work building the 2.6.23-r1 kernel
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws.
Douglas Adams (1952 - 2001)
tekwyzrd
Re: Problem:genkernel 3.4.9-pre7+8 and sabayon-sources-2.6.23-r1
Postby tekwyzrd » Fri Nov 09, 2007 20:44
Successful build using genkernel 3.4.8-r4
kernel 2.6.23-sabayon-r1 is up and running
tekwyzrd
