KMLDonkey Core? Where's it ?
Postby ZareliMan » Fri Nov 02, 2007 0:57
I was trying to use MLDonkey (very nice P2P) and I found this message:
'Now, select the full path to your MLDonkey core, which you (or your distribution) downloaded earlier, below. If the archive you downloaded only contained one file, then this is the core, otherwise look for the file called "mlnet".'
Where does the anaconda installer put that 'core' ?
Anyway nice distro, this is my first message and I hope not one of my last ones because I really liked this stuff and I'm going to use it in my notebook and, if works, on my desktop :D
ZareliMan
Re: KMLDonkey Core? Where's it ?
Postby Stupot » Fri Nov 02, 2007 1:54
Make sure you have MLDonkey installed. I think I fiddled with KMLDonkey before and had to actually install MLDonkey to get it to work. Then you'll have the core that you can lead KMLDonkey too.
