Request recommendations for photo management app. [Solved]
Postby Fitzcarraldo » Mon Oct 29, 2007 2:39
I would be grateful for advice on which photo management application would best suit my needs, as explained below.
I have several thousand digital photographs stored on my laptop's HDD in many different directories. I would like to be able to easily do as many as possible of the following:
a) View thumbnails of the photos in their original directories (i.e. I do not want the photo management application to create any new directories and import photos into it).
b) Add keywords to each photo.
c) Search photos by keyword(s).
d) Edit EXIF data in a photo to change date and time if the date and time were set wrongly in the camera at the time the photo was taken.
e) View photos in chronological order.
f) Add notes against each photo.
Items a, b and c are essential for me; the others would be nice to have.
Any advice gratefully received. Thanks in advance.
Re: Request for recommendations for photo management application
Postby atila » Mon Oct 29, 2007 14:52
Hello Fitzcarraldo,
Have you tried Picasa?
Best regards,
atila
Postby Fitzcarraldo » Mon Oct 29, 2007 18:56
Thanks for your reply, atila. No, I haven't tried it yet, as I'm hoping to get some comparisons from people before plumping for a package. I have read a little about Picassa and it looks like it might be almost what I'm after, but I read that it cannot do Item d on my list. Is that the case, do you know? Does it do everything else?
Postby atila » Mon Oct 29, 2007 20:08
I think you are right about your item d, not sure at all. In any case, it does the other points.
Btw, picasa comes as a binary in portage, so you'll install it in a couple of minutes.
Best regards,
atila
Postby joost » Tue Oct 30, 2007 11:17
Picasa.
I't pre-installed on sabayon.
Postby atila » Tue Oct 30, 2007 11:36
You are right for sabayon 3.4, I was using 3.3 due to some issues with compiz...
atila
Postby Fitzcarraldo » Tue Oct 30, 2007 14:04
Thanks for the replies so far.
How about digiKam and F-Spot? They are both listed as photo managers. Has anyone any experience using them? Do they do any/all of the things in the list I posted earlier? How do they compare with each other?
I'm looking for some advice on which is the best one to go for.
Postby joost » Tue Oct 30, 2007 14:58
Just open Picasa and see its the best yourself.
:D
Postby dunsurfin » Tue Oct 30, 2007 16:30
Fitzcarraldo wrote:Thanks for the replies so far.
Neither will do what you want. Gwenview will allow you to edit exif data so a combination of picasa and gwenview will do all you require.
Self-righteousness is a loud din raised to drown
the voice of guilt within us - Eric Hoffer
dunsurfin
Postby Fitzcarraldo » Wed Oct 31, 2007 12:20
Thanks for your useful reply, dunsurfin.
Well, I fired up Picasa and it started going through my HDD looking for photos, which started to appear in the Picasa window, but then Picasa suddenly displayed a message along the lines of "Picasa cannot continue and will close" (I cannot remember the precise words as I am not running SL at the moment) and closed/vanished. :? :(
