No Suse menu in new kicker-3.5.8-r10
Postby dave_p_b » Thu Oct 25, 2007 21:30
Help
I have not suse menu in the new kicker-3.5.8-r10. I have installed the rest of kde 3.5.8.
Has anyone tried this yet?
Many thanks
Dave
dave_p_b
Re: No Suse menu in new kicker-3.5.8-r10
Postby Fitzcarraldo » Fri Oct 26, 2007 8:21
I lost the SuSE kicker when I re-installed the previous version of KDE, but ended up liking the KDE menu better and kept it. However, would the procedure given in the Wiki for updating the Mini Edition (LiveCD) to the LiveDVD SuSE-style kicker get you back to the SuSE kicker, Dave?
http://wiki.sabayonlinux.org/index.php? ... yle_kicker
Postby dave_p_b » Sat Oct 27, 2007 2:21
Hi
Thanks for your quick reply. The dev team have just updated the kicker-3.5.8-r10 ebuild so the Suse menu is back.
Many thanks
Dave
dave_p_b
Postby christophocles » Sun Nov 04, 2007 17:15
I also lost the Suse menu when I installed kicker-3.5.8-r10. I also followed the instructions in the wiki (recompiled with -kdeinvisibility USE flag) and I still don't have it. When I try to change from KDE-style menu to SUSE-style menu, kicker reloads but the menu stays the same. How can I get back the original menu that came installed with Sabayon?
Some useful info....
$ eix kde-base/kicker
[I] kde-base/kicker
Available versions:
(3.5) 3.5.5 (~)3.5.6 3.5.7 (~)3.5.8
(0) (~)3.5.5-r90[2] (~)3.5.5-r92[2] (~)3.5.6-r91[2] (~)3.5.6-r92[2] (~)3.5.6-r93[2] 3.5.7[1] (~)3.5.7-r10[2] (~)3.5.7-r11[2] (~)3.5.7-r12[2] (~)3.5.7-r13[2] (~)3.5.8[1] (~)3.5.8-r10[2]
{arts debug elibc_FreeBSD kdeenablefinal kdehiddenvisibility kickoff pertty xcomposite xinerama}
Installed versions: 3.5.8-r10[2](01:14:32 AM 11/04/2007)(arts xcomposite xinerama -debug -elibc_FreeBSD -kdeenablefinal -kickoff)
Description: Kicker is the KDE application starter panel and is also capable of some useful applets and extensions.
[I] kde-base/kicker-applets
Available versions: (3.5) 3.5.5 (~)3.5.6 3.5.7 (~)3.5.8
{arts debug elibc_FreeBSD kdeenablefinal xinerama}
Installed versions: 3.5.8(3.5)(03:27:19 AM 11/04/2007)(arts xinerama -debug -elibc_FreeBSD -kdeenablefinal)
Homepage: http://www.kde.org/
Description: kicker applets
[1] "xeffects" /usr/portage/local/layman/xeffects
[2] "sabayon" /usr/portage/local/layman/sabayon
Found 2 matches.
christophocles
Postby momocore » Sun Nov 04, 2007 20:37
Try adding the "kickoff" use flag
# euse -E kickoff && emerge kicker
From there, either restart X or in KControl select the KDE menu, click apply, then select SUSE menu and click apply. It should be intact.
Hope that helps!
momocore
Postby christophocles » Mon Nov 05, 2007 2:40
momocore wrote:Try adding the "kickoff" use flag
Hope that helps!
Sweet, the kickoff USE flag worked like a charm. I was wondering what it was for.. I was afraid to enable it before because its description said <unknown>. Gentoo-portage.com doesn't even list it. Is it new or something?
$ euse -i kickoff
global use flags (searching: kickoff)
no matching entries found
local use flags (searching: kickoff)
$ equery uses kicker
[ Searching for packages matching kicker... ]
[ Colour Code : set unset ]
[ Legend : Left column (U) - USE flags from make.conf ]
[ : Right column (I) - USE flags packages was installed with ]
[ Found these USE variables for kde-base/kicker-3.5.8-r10 ]
U I
+ + arts : Adds support for aRts: the KDE sound daemon
- - debug : Enable extra debug codepaths, like asserts and extra output. If you want to get meaningful backtraces see http://www.gentoo.org/proj/en/qa/backtraces.xml .
- - elibc_FreeBSD : <unknown>
- - kdeenablefinal : EXPERIMENTAL: KDE ebuilds will use the enable-final flag, yielding compilation speedups at the cost of heavy mem usage and potentially causing problems. We strongly discourage setting this.
+ + kickoff : <unknown>
+ + xcomposite : Enable support for the Xorg composite extension
+ + xinerama : Add support for the xinerama X11 extension, which allows you to stretch your display across multiple monitors
christophocles
Postby momocore » Mon Nov 12, 2007 20:14
I believe its specific to the Sabayon layman, so it woudn't show up in gentoo...
momocore
Suse KDE menu no more available after KDE update
Postby velk » Wed Nov 21, 2007 11:41
Hi, i moved to kde 3.5.8 and now the Suse Menu (default sabayon KDE menu) is not available in the kcontrol center
How can i get it back ?
velk
Re: Suse KDE menu no more available after KDE update
Postby wolfden » Wed Nov 21, 2007 12:16
*sighs, the power of search
viewtopic.php?f=59&t=11188&p=66034
Use Search
Merged Redundant Topic
Postby velk » Wed Nov 21, 2007 20:20
it is not working for me;(
* checking kdebase-3.5.8.tar.bz2 ;-) ...                                 [ ok ]
 * checking kdebase-3.5-patchset-03.tar.bz2 ;-) ...                       [ ok ]
 * checking kdebase-3.5.7-kicker-kickoff-suse-642174.diff.bz2 ;-) ...     [ ok ]
 * checking kickoff-icons.tar.bz2 ;-) ...                                 [ ok ]
>>> Unpacking source...
>>> Unpacking parts of kdebase-3.5.8.tar.bz2 to /var/tmp/portage/kde-base/kicker-3.5.8/work
>>> Unpacking kdebase-3.5-patchset-03.tar.bz2 to /var/tmp/portage/kde-base/kicker-3.5.8/work
>>> Unpacking kdebase-3.5.7-kicker-kickoff-suse-642174.diff.bz2 to /var/tmp/portage/kde-base/kicker-3.5.8/work
>>> Unpacking kickoff-icons.tar.bz2 to /var/tmp/portage/kde-base/kicker-3.5.8/work
Symlinking library libkonq under /usr/kde/3.5/lib/ in source dir
 * Applying kdebase-3.5.7-kicker-kickoff-suse-642174.diff.bz2 ...
 * Failed Patch: kdebase-3.5.7-kicker-kickoff-suse-642174.diff.bz2 !
 *  ( /var/tmp/portage/kde-base/kicker-3.5.8/temp/11904.patch )
 * Include in your bugreport the contents of:
 *   /var/tmp/portage/kde-base/kicker-3.5.8/temp/kdebase-3.5.7-kicker-kickoff-suse-642174.diff.bz2-11904.out
 * ERROR: kde-base/kicker-3.5.8 failed.
 * Call stack:
 *             ebuild.sh, line 1701:  Called dyn_unpack
 *             ebuild.sh, line  817:  Called qa_call 'src_unpack'
 *             ebuild.sh, line   44:  Called src_unpack
 *   kicker-3.5.8.ebuild, line   68:  Called epatch '/var/tmp/portage/kde-base/kicker-3.5.8/distdir/kdebase-3.5.7-kicker-kickoff-suse-642174.diff.bz2'
 *         eutils.eclass, line  304:  Called die
 *                              die "Failed Patch: ${patchname}!"
 *  The die message:
 *   Failed Patch: kdebase-3.5.7-kicker-kickoff-suse-642174.diff.bz2!
 * A complete build log is located at '/var/tmp/portage/kde-base/kicker-3.5.8/temp/build.log'.
 * Messages for package kde-base/kicker-3.5.8:
 * Call stack:
 *  The die message:
velk
