How do i make my "firestarter" firewall autostart on boot up
Postby zman » Wed Oct 17, 2007 18:44
I have installed firestarter and runs fine and works great by everytime i boot up i have to started it manually. Is there something like "services" in windows where i can set or check to see if firewall is running or not. Or maybe a comand line.
New linux user
zman
zman
Re: How do i make my "firestarter" firewall autostart on boot up
Postby koch » Thu Oct 18, 2007 3:06
http://wiki.sabayonlinux.org/index.php?title=Security
read this...
it is easy to find if you search :wink:
WINDOWS: Buy it, use it, break it, fix it, trash it, melt - upgrade it, charge it, pawn it, zoom it, press it, snap it, write it, get it, paste it, save it, load it, check it, plug it, play it, burn it, rip it, drag and drop it - stop. format it.
koch
Postby Fitzcarraldo » Thu Oct 18, 2007 18:14
Firestarter is no longer in Portage, and apparently has some bugs from what I've read:
viewtopic.php?f=3&t=7714
Postby koch » Thu Oct 18, 2007 18:40
that's also somewhere in the wiki...use kmyfirewall instead.
koch
Postby wolfden » Thu Oct 18, 2007 21:53
Yes, development on firestarter has died, no longer supported
