setting up a .jar for install as in double click this icon??
Postby mikey0000 » Tue Oct 16, 2007 12:40
hello
Im wondering how i could set up a .jar file (Drjava) to be an executable in the KDE menu
so i dont have to type java -jar to the file and i can move it to somewhere better than my desktop
i also have to tell it where tools.java is everytime i open it.
so im guessing ill stick it in the same directory as tools.jar and make some sort of shortcut to it launching it.
How do i do this? so it would work the same as Azureus, double click an icon.
cheers
also if i have failed to find obvious help files a sorry in advance but i dont know how to search for this kind of problem.
triple Booting Mac-osx 10.6, Sabayon Linux and Windows 7
2.5 athlon dual core
DFI infinity mobo
2 gb of DDR2 800 G skill ram 3.3.3.12
nvidia 9600gt
housed in a thermaltake taser III case with 7 fans - all turned off lol
mikey0000
Re: setting up a .jar for install as in double click this icon??
Postby rand.a » Tue Oct 16, 2007 14:28
right click, open with, "java -jar"
if that doesnt work, just create a script that has "java -jar $1" and open the file with that.
rand.a
Postby mikey0000 » Tue Oct 16, 2007 21:09
ive tried to make the script file so it looks to where ive placed the drjava app but it just opens in kwrite? what have i done or not done??
so its named Drjava.sh which i assume is a script file
and ive put in it
java -jar $/opt/sun-jdk-1.5.0.11/lib/drjava-stable-20061025-1556.jar
is that right??
DFI infinity mobo
nvidia 9600gt
mikey0000
