xkeyboard layout problem [Solved]
Postby velk » Sun Oct 14, 2007 13:21
After doing some updates on my system i experience now problems with my keyboard
I use a french keyboard (104 keys, variant latin9)
the icon of Kxkb in the task bar now display "err" and if i type this comand in a terminal i get an errror
nico@access-dev1 ~ $ setxkbmap -model pc104 -layout fr -variant latin9
Error loading new keyboard description
my keyboard layout is broken and i cant type a lot of specials characters.
i checked /usr/share/X11/symbols/pc/fr and the file is ok.
I already try to unmerge/emerge xkbdata but the problem still remain the same
how can i fix this ?
velk
Re: xkeyboard layout problem
Postby velk » Sun Oct 14, 2007 15:29
i fixed this, i removed xkbdata and install xkeyboard-config
things are now ok
velk
