where is kdelibs-devel?
Postby superpat » Sat Oct 13, 2007 21:02
I am trying to install (from source, no ebuild) the PDA program plptools v 0.18
This compiles fine without kde support!
However when I tell config to build with kde support, the configure program fails stating that:-
Checking for kde configure error. In the prefix you have chosen there are no KDE headers installed, this will fail. So check this please and use another prefix.
NOW I AM POSITIVE I AM USING THE CORRECT PREFIX. However reading the README file it states that a prerequisite is that :-
(install kde stuff) This needs installed KDE (=>2) headers/development libraries as well as QT (=>) 2.2.4 headers/development libraries.
Please can someone put me out of my misery and tell me where I can find the kdelibs-devel and kdebase-devel packages. I cannot see them in Gentoo portage or Sabayon SVN!
regards
Patrick
superpat
Re: where is kdelibs-devel?
Postby wolfden » Sat Oct 13, 2007 21:07
is there a reason why you need that particular version?
plptools-0.13 is in portage.
I myself would download the ebuild and look at it and see If I couldn't get it to do the 0.18
Postby rand.a » Sat Oct 13, 2007 22:40
Should be easy to update the ebuild for that version. Check out the guide:
http://gentoo-wiki.com/HOWTO_Create_an_Updated_Ebuild
rand.a
Postby superpat » Sun Oct 14, 2007 0:19
@wolfden
Version 0.18 is essential due to changes in versions of qt and gcc used now, V 0.13 dates from 2005!
@convict
EVEN if I updated the ebuild for o.13, it would still fail with the same problem with KDE devel libs.
plptools is a toolkit of 4-5 command line apps plus a KIO slave library app
BOTH versions need the devel libs to compile the KDE portion of the program!
All I want to know is how to get the kdelibs-devel package??????????
Please!
EDIT 13:40 14-10-2007
@convict.
Looking at the 0.13 ebuild, ALL that the ebuild is checking for is kdebase- kdelibs NOT kde-devel libs.
I already have kdebase-kdelibs installed.
The README for plptools SPECIFICALLY states that it needs kdelibs-devel package to be able to compile the kde part of the program
Patrick
superpat
Postby superpat » Sun Oct 14, 2007 22:00
Well I have got past the configure problem, it did not REALLY need kde devel libs, that part of the README appears to be a fossil from a very old version!!!!
Now of course the compile fails --- ( what else!)
The problem with the configure, was that it was not checking the installed file structures correctly!
I finally had to give this command:
>./configure --enable-kde --with-kdedir=/usr/kde/3.5/ --prefix=/usr  --with-qt-dir=/usr/qt/3/ --with-kdeversion=3
Configure now produces the MAKEFILES OK, but when the KIOslave part of the kde app is compiling it bombs with
 g++ -shared -nostdlib /usr/lib/gcc/i586-pc-linux-gnu/4.1.2/../../../crti.o /usr/lib/gcc/i586-pc-linux-gnu/4.1.2/crtbeginS.o  .libs/plpprops.o .libs/plppropsFactory.o .libs/pie3dpiece.o .libs/pie3dwidget.o .libs/libplpprops_la_meta_unload.o  -Wl,--rpath -Wl,/home/patrick/plptools-0.18/lib/.libs -Wl,--rpath -Wl,/usr/kde/3.5/lib -Wl,--rpath -Wl,/usr/qt/3/lib -L/home/patrick/plptools-0.18/lib/.libs -L/usr/kde/3.5//lib ../../lib/.libs/libplp.so /usr/kde/3.5/lib/libkio.so -lkfile -lnsl -L/usr/lib/gcc/i586-pc-linux-gnu/4.1.2 -L/usr/lib/gcc/i586-pc-linux-gnu/4.1.2/../../../../i586-pc-linux-gnu/lib -L/usr/lib/gcc/i586-pc-linux-gnu/4.1.2/../../.. -lstdc++ -lm -lc -lgcc_s /usr/lib/gcc/i586-pc-linux-gnu/4.1.2/crtendS.o /usr/lib/gcc/i586-pc-linux-gnu/4.1.2/../../../crtn.o  -Wl,-soname -Wl,libplpprops.so -o .libs/libplpprops.so
/usr/lib/gcc/i586-pc-linux-gnu/4.1.2/../../../../i586-pc-linux-gnu/bin/ld: cannot find -lkfile
collect2: ld returned 1 exit status
make[2]: *** [libplpprops.la] Error 1
make[2]: Leaving directory `/home/patrick/plptools-0.18/kde2/plugins'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/patrick/plptools-0.18/kde2'
make: *** [all-recursive] Error 1
What is the missing "-lkfile" ?
How do I fix this?
regards
Patrick
superpat
Postby cyrwyn » Mon Oct 15, 2007 16:47
When you see a line in compile that is like "-lkfile", the "l" means library. So, there is a missing development library that is needed or needs a path to it if it is installed. Any KDE program must have some of the KDE-devel libs to compile, as well as QT-devel.
cyrwyn
Postby superpat » Mon Oct 15, 2007 18:56
@cyrwyn
Thankyou!
Have I understood this correctly, even though the configure program does not barf about no kde-devel libs any more, plptools is failing to compile because it DOES need the kde-devel libs?
If that is the case, WHERE CAN I find the package or rpm or whatever?
Back to square one!
regards
Patrick
superpat
