wmv files dont play well in smplayer or any player
Postby slampy » Fri Oct 12, 2007 17:19
I find that when I open my WMV files they look all garbled and discolored. this is only with WMV files. all my AVI and other video files play fine. is there a codec or something I can update to fix this? thanks.
Running 3.4e 32bit version with an Athlon64 and an nvidia geforce 7800gt. I'm a linux beginner and first time sabayon user. :D
slampy
Re: wmv files dont play well in smplayer or any player
Postby CygX-1 » Fri Oct 12, 2007 22:32
Could be a missing codec. But since Sabayon comes with almost any codec you can think of, you are more likely talking about DRM-protected files; unfortunately there's no way to play them under linux. That garbage is intended for Windows (and MacOS) only.
CygX-1
Users browsing this forum: TDKyon and 1 guest
