Kompozer 0.7.10
Kompozer 0.7.10
Postby wolfden » Mon Oct 08, 2007 1:25
I know some have been asking about this. http://www.kompozer.net/download.php
I was scanning the gentoo forum like usual and some nice person has made an ebuild for it
http://forums.gentoo.org/viewtopic-t-565017.html
Please see for how to install 3rd party ebuilds:
http://gentoo-wiki.com/HOWTO_Installing ... ty_Ebuilds
# Copyright 1999-2007 Gentoo Foundation
# Distributed under the terms of the GNU General Public License v2
# $Header: /var/cvsroot/gentoo-x86/app-editors/nvu/nvu-1.0-r4.ebuild,v 1.10 2007
/03/02 09:22:52 armin76 Exp $
inherit eutils mozconfig flag-o-matic multilib
DESCRIPTION="A WYSIWYG web editor for linux similiar to Dreamweaver"
HOMEPAGE="http://www.kompozer.net/"
SRC_URI="http://downloads.sourceforge.net/kompozer/kompozer-${PV}dfsg-src.tar.gz
LICENSE="GPL-2"
SLOT="0"
KEYWORDS="amd64 ppc sparc x86"
IUSE=""
DEPEND="x11-proto/printproto
        sys-apps/gawk
        dev-lang/perl
        >=media-libs/freetype-2.1.9-r1"
S=${WORKDIR}/${P}/mozilla
src_unpack() {
        unpack ${A}
        cd ${S}
        # I had to manually edit the mozconfig.linux file as it
        # has some quirks... just copy the darn thing over :) - Chris
        # copied from mozilla.eclass (modified slightly),
        # otherwise it defaults to -O which crashes on startup for me - basic
        # Set optimization level based on CFLAGS
        if is-flag -O0; then
                echo 'ac_add_options --enable-optimize=-O0' >> .mozconfig
        elif is-flag -O1; then
                echo 'ac_add_options --enable-optimize=-O1' >> .mozconfig
        else
                # mozilla fallback
                echo 'ac_add_options --enable-optimize=-O2' >> .mozconfig
        fi
src_compile() {
        # The build system is a weeee bit sensitive to naughty -O flags.
        # filter them out and let the build system figure out what
        # won't let it die :) - Chris
        filter-flags '-O*'
        make -f client.mk build_all || die "Make failed"
src_install() {
        make -f client.mk DESTDIR=${D} install || die
        #menu entry for gnome/kde
#       insinto /usr/share/applications
#       sed -e "s:/usr/lib/nvu:/usr/$(get_libdir)/nvu:" \
#               ${FILESDIR}/1.0/nvu.desktop > ${T}/nvu.desktop
#       doins ${T}/nvu.desktop
