Programs Are Starting To Not Open
Postby lucknuts » Fri Oct 05, 2007 22:57
I installed Sabayon 32bit once again last night.
Now today, so far I did a
emerge --sync
, and
layman -s sabayon && euse -E kickoff && emerge kicker desktop-acceleration-helpers
to help out with the compiz fusion.
After running
I noticed that portato i can click on it will say its going to open but then it just doesn't open.
I click on the compiz-fusion icon, and it does not open either. same with a couple other programs.
I also got rid of udev-109 I believe it was and replaced it with udev-114.
What is it that has happened?
Yes, I'm new at this.
Will learn. WIll teach.
lucknuts
Re: Programs Are Starting To Not Open
Postby joost » Fri Oct 05, 2007 23:22
To know what is happening, open program from terminal and read the feedback.
:D
Postby lucknuts » Fri Oct 05, 2007 23:47
joost wrote:To know what is happening, open program from terminal and read the feedback.
:D
I thought I could right click and click open in terminal but I figured out that I can't...
How do you do it in the terminal?]
I type help and didn't really see anything that would.....well help me out.
lucknuts
Postby wolfden » Sat Oct 06, 2007 1:23
enter the name of the program
to find names, use the tab complete
fusio tab tab
but u can run
fusion-icon
portato
Postby lucknuts » Sat Oct 06, 2007 2:25
wolfden wrote:enter the name of the program
fusio tab tab
but u can run
fusion-icon
portato
I said screw it and reinstalled sabayon once again, looks like this time will be a charm so far. ha.
I ended up having dbus errors and it wouldn't work because compiz-icon wouldn't load....blah....
lucknuts
