Already did it
but may be there is something else...
I've just did
emerge --sync
and then
emerge portage
After that I decided to update system and world - as abayon is running on my amd machine - so I've changed the make.conf and give a try
but...
emerge system -v
Calculating system dependencies... done!
[ebuild U ] sys-apps/portage-2.1.3.11 [2.1.3.9] USE="-build -doc -epydoc (-selinux)" LINGUAS="-pl" 40 kB
*** Portage will stop merging at this point and reload itself,
then resume the merge.
[ebuild N ] sys-apps/man-1.6e-r3 USE="nls" 247 kB
[ebuild U ] sys-apps/util-linux-2.13-r1 [2.12r-r6] USE="nls -old-linux% (-selinux) (-crypt%*) (-old-crypt%) (-perl%*) (-static%)" 2,640 kB
[ebuild U ] sys-apps/kbd-1.13-r1 [1.12-r8] USE="nls" 652 kB
[ebuild U ] sys-apps/busybox-1.7.1 [1.5.0] USE="pam%* -debug -make-symlinks -savedconfig (-selinux) -static" 1,688 kB
[ebuild U ] sys-devel/libtool-1.5.24 [1.5.23b] USE="-vanilla%" 2,852 kB
[ebuild U ] sys-devel/flex-2.5.33-r3 [2.5.33-r2] USE="nls -static" 680 kB
[ebuild U ] sys-apps/gawk-3.1.5-r5 [3.1.5-r3] USE="nls" 2,257 kB
[ebuild U ] app-arch/tar-1.18-r2 [1.16.1] USE="nls -static" 1,834 kB
[ebuild U ] sys-apps/shadow-4.0.18.1-r1 [4.0.18.1] USE="cracklib nls pam -nousuid (-selinux) -skey" 1,481 kB
[ebuild U ] sys-process/psmisc-22.5-r2 [22.5] USE="X ipv6 nls (-selinux)" 271 kB
[ebuild U ] sys-libs/readline-5.2_p7 [5.2_p2] 2,008 kB
[ebuild U ] sys-apps/file-4.21-r1 [4.20-r1] USE="python" 538 kB
[ebuild U ] app-arch/bzip2-1.0.4-r1 [1.0.4] USE="-static" 822 kB
[ebuild U ] sys-libs/ncurses-5.6-r2 [5.6-r1] USE="gpm unicode -bootstrap -build -debug -doc -minimal -nocxx -profile% -trace" 2,353 kB
[ebuild U ] net-misc/rsync-2.6.9-r4 [2.6.9-r2] USE="acl* ipv6 -static -xinetd" 793 kB
[ebuild U ] sys-apps/debianutils-2.25 [2.17.5] USE="-static" 133 kB
[ebuild U ] app-editors/nano-2.0.6 [2.0.4] USE="ncurses nls unicode -debug -justify -minimal -slang -spell*" 1,285 kB
[ebuild U ] app-arch/cpio-2.9 [2.7-r2] USE="nls" 741 kB
[ebuild U ] sys-apps/coreutils-6.9-r1 [6.9] USE="nls -acl (-selinux) -static -xattr" 5,307 kB
[ebuild N ] sys-apps/hdparm-7.7 62 kB
[ebuild U ] sys-apps/baselayout-1.12.10-r5 [1.12.10-r3] USE="unicode -bootstrap -build -static" 214 kB
[ebuild U ] net-misc/openssh-4.7_p1-r2 [4.6_p1-r1] USE="X kerberos pam tcpd -X509 -chroot -hpn -ldap -libedit (-selinux) -skey -smartcard -static" 968 kB
[ebuild U ] sys-fs/udev-115-r1 [109-r1] USE="(-selinux)" 210 kB
[ebuild U ] sys-apps/findutils-4.3.8-r1 [4.3.2-r1] USE="nls (-selinux) -static" 1,766 kB
[ebuild U ] sys-kernel/linux-headers-2.6.22-r2 [2.6.19.2-r2] 4,599 kB
[ebuild U ] sys-devel/m4-1.4.10 [1.4.9] USE="nls -examples" 722 kB
[ebuild U ] sys-apps/less-406 [394] USE="unicode" 480 kB
[ebuild UD] sys-devel/binutils-2.18 [2.18.50.0.1] USE="nls -multislot -multitarget -test -vanilla" 14,622 kB
[ebuild U ] app-shells/bash-3.2_p17-r1 [3.2_p15-r1] USE="nls -afs -bashlogger -plugins% -vanilla" 2,522 kB
[ebuild U ] sys-libs/glibc-2.6.1 [2.5-r1] USE="nls -debug -glibc-compat20 -glibc-omitfp (-hardened) (-multilib) -profile (-selinux) (-build%) (-nptl%*) (-nptlonly%*)" 16,006 kB
[ebuild U ] sys-devel/autoconf-2.61-r1 [2.61] USE="-emacs" 1,365 kB
[ebuild U ] sys-devel/gnuconfig-20070724 [20070118] 40 kB
[ebuild NS ] sys-devel/gcc-4.2.0 USE="fortran gcj mudflap nls openmp (-altivec) -bootstrap -build -doc -gtk (-hardened) -ip28 -ip32r10k (-multilib) -multislot (-n32) (-n64) -nocxx -objc -objc++ -objc-gc -test -vanilla" 43,093 kB
[ebuild N ] sys-apps/man-pages-2.65 USE="nls" 1,807 kB
[ebuild U ] sys-apps/diffutils-2.8.7-r2 [2.8.7-r1] USE="nls -static" 1,038 kB
[blocks B ] >=sys-apps/util-linux-2.13_pre (is blocking sys-process/schedutils-1.5.0)
[blocks B ] <sys-fs/device-mapper-1.02.19-r1 (is blocking sys-fs/udev-115-r1)
[blocks B ] <sys-apps/baselayout-2.0.0_rc (is blocking sys-apps/makedev-3.23.1)
[blocks B ] sys-process/schedutils (is blocking sys-apps/util-linux-2.13-r1)
Total: 36 packages (31 upgrades, 1 downgrade, 3 new, 1 in new slot, 4 blocks), Size of downloads: 118,119 kB
!!! Error: The above package list contains packages which cannot be installed
!!! at the same time on the same system.
For more information about Blocked Packages, please refer to the following
section of the Gentoo Linux x86 Handbook (architecture is irrelevant):
http://www.gentoo.org/doc/en/handbook/h ... =1#blockedemerge world -v
Calculating world dependencies /
!!! All ebuilds that could satisfy ">=x11-base/xorg-server-1.3.99" have been masked.
- x11-base/xorg-server-1.4-r1 (masked by: package.mask)
/etc/portage/package.mask:
#=media-sound/jack-audio-connection-kit-0.102.20
- x11-base/xorg-server-1.4-r2 (masked by: package.mask)
For more information, see MASKED PACKAGES section in the emerge man page or
refer to the Gentoo Handbook.
(dependency required by "x11-drivers/xf86-input-dmc-1.1.1" [ebuild])
!!! Problem resolving dependencies for x11-drivers/xf86-input-dmc
!!! Depgraph creation failed.
I don know...what to do yestarday I install sabayon and equo was running...then I reinstall it....and now it doesnt
Is this tool is included in DVD?
