KXDocker
KXDocker
Postby timboellis » Thu Sep 27, 2007 2:06
Before i go to reinstall SL I would like to try a few bits and bobs one of whick is KXDocker, but on all the forums in here i tried all the options with emerge kxdocker , emerge =kxdocker-1.1.4a-r2 and so on but every time i get emerge =kxdocker-1.1.4a-r2
Can we stil get this and if so how?
timboellis
Re: KXDocker
Postby navman » Thu Sep 27, 2007 2:17
portato, or kuroo even porthole gui's offer a great catalog for portage
navman
Re: KXDocker
Postby wolfden » Thu Sep 27, 2007 3:02
kxdocker is in the xeffects overlay, so you have to add that, than emerge it
I see:
Available versions: 1.1.4a-r2
as only version
Re: KXDocker
Postby timboellis » Thu Sep 27, 2007 8:46
I have tried portato and Kuroo but cannto find the package
timboellis
Re: KXDocker
Postby wolfden » Thu Sep 27, 2007 9:21
wolfden wrote:kxdocker is in the xeffects overlay, so you have to add that, than emerge it
I see:
as only version
that is why I posted the above, you not going to find it in portato or kuroo.
layman -a xeffects
emerge -s kxdocker
Re: KXDocker
Postby edgevision » Fri Sep 28, 2007 19:00
KXDocker is amazing and works incredibly well with Compiz if you uncheck the "Auto send the docker to background layer" option in the configurator. XQDE will be even more impressive, when a stable release is available.
edgevision
Re: KXDocker
Postby timboellis » Fri Oct 26, 2007 2:15
Still getting no joy with KXdocker any help at all
>>> Verifying ebuild Manifests...
>>> starting parallel fetching
>>> Emerging (1 of 10) kde-misc/kxdocker-1.1.4a-r2 to /
>>> Downloading 'http://distfiles.gentoo.org/distfiles/kxdocker-1.1.4a.tar.bz2'
--02:14:54--  http://distfiles.gentoo.org/distfiles/kxdocker-1.1.4a.tar.bz2
           => `/usr/portage/distfiles/kxdocker-1.1.4a.tar.bz2'
Resolving distfiles.gentoo.org... 216.165.129.135, 156.56.247.195, 140.211.166.134, ...
Connecting to distfiles.gentoo.org|216.165.129.135|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
02:14:55 ERROR 404: Not Found.
>>> Downloading 'http://distro.ibiblio.org/pub/linux/distributions/gentoo/distfiles/kxdocker-1.1.4a.tar.bz2'
--02:14:55--  http://distro.ibiblio.org/pub/linux/distributions/gentoo/distfiles/kxdocker-1.1.4a.tar.bz2
Resolving distro.ibiblio.org... 152.46.7.109
Connecting to distro.ibiblio.org|152.46.7.109|:80... connected.
02:14:57 ERROR 404: Not Found.
>>> Downloading 'http://www.xiaprojects.com/www/downloads/files/kxdocker/1.0.0/kxdocker-1.1.4a.tar.bz2'
--02:14:57--  http://www.xiaprojects.com/www/downloads/files/kxdocker/1.0.0/kxdocker-1.1.4a.tar.bz2
Resolving www.xiaprojects.com... 80.241.171.181
Connecting to www.xiaprojects.com|80.241.171.181|:80... connected.
02:14:58 ERROR 404: Not Found.
!!! Couldn't download 'kxdocker-1.1.4a.tar.bz2'. Aborting.
timboellis
Re: KXDocker
Postby Stupot » Fri Oct 26, 2007 4:08
It's failing for me too. I think the webserver is down, or maybe they're in the middle of releasing an update. Only time will tell.
Re: KXDocker
Postby timboellis » Sat Oct 27, 2007 20:18
Managed to suss it I done a google search for kxdocker-1.1.4a.tar.bz2 downloaded it into usr/portage/distfiles then run emerge kxdocker
timboellis
Re: KXDocker
Postby timboellis » Sat Oct 27, 2007 20:58
I lied it did nto work I had to download all the files from http://www.xiaprojects.com/index.php?se ... 20sources# and it is runnign so far so good up to 8/10
timboellis
