mp4 encoding apps in sabayon
Postby ToneDeaf » Tue Sep 18, 2007 3:34
OK, after thinking about it a lot, I've decided to move my iTunes multimedia collection to Sabayon. However, I do have a few questions. How am I going to sync the data, including video? and, should I keep using my old ad-riddled Windows mpeg converter app or is there a native linux gui in sabayon/portage? I've tried amarok and loved it, so my only real worry is about converting and syncing movies.
Please Respond, or I may be stuck with windows forever.
Thank you,
ToneDeaf
ToneDeaf
Re: mp4 encoding apps in sabayon
Postby WarraWarra » Wed Sep 19, 2007 8:23
http://www.gtk-apps.org/content/show.ph ... tent=64899
http://gentoo-portage.com/Search?search=mp4
http://linux.softpedia.com/progSearch
add mp4 converter to the search right top of page.
I have several cd's that got stuck with itunes in locked mp4's / aac even though they are cd to itunes ripped in itunes when Itunes had this bug and now cd's is missing.
Aac+ is the default choice now for me 128kbs mp3 steaming in 24kbps to 32kbps aac+ and sounds better + takes up less space not sure about video maybe h.264 think in portage is ?264 or in the USE flags this can be added.
http://www.di.fm
Wine door can install winamp or advertisement converter program as well , maybe burn the aac / mp4 files to cd-rw and then import them again or something not sure about video's.
or convert all of them to mp3 in windows and import to linux ?
Remember to uncertify or what is it called the pc itunes is on otherwise itunes has issues in future "account can not be used on more than 5 pc's" excuses.
Best of luck and post if you find something I can see many persons moving over might want to do the same.
WarraWarra
Postby Thev00d00 » Wed Sep 26, 2007 21:46
use Wine / MediaCoder
mediacoder is great, lots of profiles, phones, ipods, h254 etc...... v good program!
http://mediacoder.sourceforge.net/wiki/ ... r_on_Linux
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
Thev00d00
Generally Awesome (tm)
Postby webdesigner » Sat Nov 24, 2007 22:51
have you gut any luck with that ?
Mohammed,
Senior Web Designer
Web Design in Egypt
webdesigner
Postby hoodooman » Sun Nov 25, 2007 21:13
ffmpeg will encode to mp4 (as long as you have the libmp4 installed too.)It will do audio or video.For audio only I would use ecasound and the ecaconvert command.
hoodooman
Postby Azerthoth » Sun Nov 25, 2007 23:49
Here is a nice little article on media conversion:
http://www.linux.com/feature/121385
Very recent, and very helpfull.
Azerthoth
