Amarok & Xine?? problem (SOLVED)
Postby chsims1 » Fri Sep 14, 2007 11:25
After a fresh installation of 3.4f I emerged amarok, but I get an error along the lines of "Audio output unavailable; the device is busy" whenever I try & play any tracks. System sounds work fine & I previously had Amarok working without any problems. Any pointers as to where I should be looking to solve this problem please?
chsims1
Re: Amarok & Xine?? problem
Postby chsims1 » Sat Sep 15, 2007 13:18
Ok sorted after a lot of fiddling. The USE flag for ALSA was not set for xine-lib:
USE ="alsa" emerge xine-lib
It all works fine now :D
chsims1
