wolfden wrote:Try with grub adding acpi_osi=Linux ?
No joy
Fitzcarraldo wrote:I see from your /var/log/messages file that you're using the 3.7.0 kernel. Some Gentoo users are having ALSA trouble with the 3.7.0 kernel (and/or udev), so perhaps you're suffering from the same thing: Problem with alsasound after Kernel 3.7.0 upgrade. Have you tried reverting to a 3.6.* kernel to see if it has an effect?
