How to install Epson nx130 Printer in Sabayon 9 G 64Bit?
Postby eor2004 » Mon Aug 13, 2012 18:16
Hi friends, Sometime ago I was using sabayon 9 Gnome 32-Bit version and my printer an Epson NX130 was recognized and installed without too much effort going to "System Settings/Printers" and clicking the add printer button. Now I'm using Sabayon 9 Gnome 64-Bit version and my printer is Not recognized and I can't install it no matter what I do, so I was asking if someone could tell me why is this happening, right now I'm more interested in knowing why it can install in the 32bit version but not in the 64bit version :? . I think it will be better to get me an HP printer because it does have linux native driver support and will not have these problems with an HP printer, does anyone had trouble getting an HP printer to work with sabayon 64_Bit? Your answers will be of great help, thank you beforehand! :)
Sabayon Linux 9 Gnome Shell!
eor2004
Re: Why can't install Epson Printer in Sabayon 9 G 64Bit?
Postby svantoviit » Mon Aug 13, 2012 21:43
My suggestions are:
  1. Check with lsusb if the printer is recognized
  2. Try to install the printer through CUPS: open a browser and navigate to http://localhost:631/
  3. If it still doesn't work, install additional printer drivers and try again: net-print/gutenprint
eor2004 wrote:does anyone had trouble getting an HP printer to work with sabayon 64_Bit?
One should always check beforehand, if a device will work with Linux and all features are supported. It applies to HP products too. This way you can skip a lot of headaches and wasted time.
svantoviit
Postby eor2004 » Tue Aug 14, 2012 2:56
This is the message I get everytime I try to install the printer, do you know what it means?
"FirewallD is not running. Network printer detection needs services mdns, ipp, ipp-client and samba-client enabled on firewall."
and yes, using "lsusb" the printer is listed as you can see below:
Bus 001 Device 006: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 002 Device 002: ID 046d:c31b Logitech, Inc. Compact Keyboard K300
Bus 002 Device 003: ID 046d:c03f Logitech, Inc. M-BT85 [UltraX Optical Mouse]
Bus 003 Device 002: ID 0e8f:0003 GreenAsia Inc. MaxFire Blaze2
Bus 003 Device 003: ID 04b8:0883 Seiko Epson Corp.<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<(this is the printer)<<<<<<<<<<
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
eor2004
Re: How to install Epson nx130 Printer in Sabayon 9 G 64Bit?
Postby Fitzcarraldo » Tue Aug 14, 2012 5:31
Try turning the firewall off.
Postby eor2004 » Tue Aug 14, 2012 6:14
Fitzcarraldo wrote:Try turning the firewall off.
I disabled and uninstalled firewall but it didn't worked, thak you anyway :)
Will be using printer via windows xp in Virtual Box it works this way!
eor2004
Return to Hardware
