mgn wrote:My PC config. -- Intel Dual Core Processor, 512 ram, 160 GB HD and No graphic Card
nano -w /etc/X11/xorg.confOption "ConnectedMonitor" "DFP"
Option "FlatPanel" "True"
-> 5.0 Gnome
-> 3800+ (2.01 GHz)
bluecrxnc wrote:Need more details.
When does the screen go blank with that message?
I had something like this happen to me that I wasn't ready for. As soon as the login screen should appear the LCD monitor ditches. Just had to [ALT]+[F1]... login in as root and
- Code: Select all
and add the following to the 'Device'
- Code: Select all
Need more details.
-> 5.0 Gnome
-> 3800+ (2.01 GHz)
noddc res=1440x900 refresh=60bluecrxnc wrote:Need more details.
It's kind of hard to help without more information. Previous info was just a shot in the dark based on my personal experience.
Fitzcarraldo wrote:Have you tried adding:
- Code: Select all
to the kernel parameters when you boot? (Change 1440x900 to the resolution of your monitor).
res=1024*768mgn wrote:No external Graphic Card
Return to Installer Issues - Anaconda **Not for Package Manager Stuff**
